wayne1978trucks Posted April 20, 2017 Share Posted April 20, 2017 This morning towing our trailer with 2 ton on, got to the lights then pulled off and could feel a slight vibration, as I changed into 3rd it got worse. If you are coasting out of gear its still there. As you accelerate its less, it gets worse on deceleration. Stopped on level ground with the handbrake off and when I twist the front prop one way then the other itsounds like its clicking at the swivel area. When I twist hard on the front prop it feels like I can click it past a stiff point like its moving a spline one way then back a spline. Looks like im stripping it at the weekend but any ideas? Thanks Wayne. Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 20, 2017 Share Posted April 20, 2017 It could be many things, but a bad prop shaft UJ is prime suspect. Quote Link to comment Share on other sites More sharing options...
gerrymc123 Posted April 20, 2017 Share Posted April 20, 2017 If you want to check the UJ's for play you'll need to jack-up the vehicle, it can't be done when the wheels are still on the ground. Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 21, 2017 Share Posted April 21, 2017 16 hours ago, gerrymc123 said: If you want to check the UJ's for play you'll need to jack-up the vehicle, it can't be done when the wheels are still on the ground. More specifically, you can't properly check a UJ with the prop shaft fitted tot he vehicle. Jacking it up is not required - the prop has to come off and each UJ checks for full movement in every axis, both unladen and with torsional loads applied in each direction to feel for grooved bearing surfaces. Quote Link to comment Share on other sites More sharing options...
wayne1978trucks Posted April 21, 2017 Author Share Posted April 21, 2017 lads your bang on , we have had it in the garage today taken the prop off an its the uj nearest the transfer box, its knackered but only one of the four bearings are gone so if anyone else gets same symptoms then it may be this, oh and the nearside click is the drive flange ....a lot of play. by the way the slider on the prop is very stiff , do you think this is the cause of the failure? many thanks to the replies chaps. wayne Quote Link to comment Share on other sites More sharing options...
wayne1978trucks Posted April 22, 2017 Author Share Posted April 22, 2017 update I noticed also that a weight is missing the 4 spot welds are there and a square patch of rust but no weight so that also may have been a contribution. wayne Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 22, 2017 Share Posted April 22, 2017 A missing balance weight will have some effect on vibration, but probably only enough to be a minr irritation and not enough to significantly affect mechanical wear. A seized slip joint, on the other hand, will place significant thrust loads on the UJs and the transfer box and diff bearings, causing significant vibration and premature bearing failures. That is a big deal. Strip the slip joint' clean it with solvent (petrol will suffice) and a toothbrush, and reassemble regreased and test the joint. It should slide smoothly. If not, bin it and replace the whole shaft. Glad you found the culprit, and that it was the easiest and cheapest. Quote Link to comment Share on other sites More sharing options...
gerrymc123 Posted April 23, 2017 Share Posted April 23, 2017 (edited) MOT centers issue failures on UJ's after jacking up the vehicle, carrying out a visual inspection and hand manipulating the joint, this is done without the prop shaft being removed, go figure. Edited April 23, 2017 by gerrymc123 Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 23, 2017 Share Posted April 23, 2017 Gerry, that only reveals a UJ so far gone that it is already disintegrating. It does not reveal a binding UJ. An MoT inspection is to determine whether a vehicle meets a minimum standard of roadworthiness and that it is not fundamentally dangerous. It is not a check on the reliability of, or sufficient maintenance of, a vehicle. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted April 23, 2017 Share Posted April 23, 2017 9 hours ago, gerrymc123 said: MOT centers issue failures on UJ's after jacking up the vehicle, carrying out a visual inspection and hand manipulating the joint, this is done without the prop shaft being removed, go figure. Are you sure? My MOT centre says that UJs are not part of the test. Quote Link to comment Share on other sites More sharing options...
wayne1978trucks Posted April 23, 2017 Author Share Posted April 23, 2017 well spare prop has gone on the sliding joint is seized beyond .....so in the bin its gone, just need to order the new prop as this one is just a get me on the road for Monday prop. while I was at it all I noticed I need to order a n/s cv joint as that's got some play and the seals that stop the diff oil from getting to the drive flanges, I did drop in the 2 new rear half shafts while under there and the 4 hd drive flanges that have been sitting on the bench for 12 months, and guess what it now dosent clunk like someone has crashed into the back of me when I pull off. ( I'm shocked how much play was in the flanges and one of the shafts was close to no teeth) so the repair/service list got shorter........then longer again. thanks again guys wayne Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 24, 2017 Share Posted April 24, 2017 Don't replace the seal inside the stub axle. Remove it, or wreck it, and do the same to the others! Allowing oil past those seals lubricates the drive flange and shaft splines, preventing the very wear you found at the back, and also keeps the wheel bearings healthy. LR may claim to have put the seals in to stop oil getting out of the plastic cone joint on the flange, but 90s have integrated shafts and flanges on the back end. The only reason for that seal is to keep the splines and wheel bearings dry and increase maintenance spending. They have absolutely no positive effect on parts longevity. As for the CV joint, it's a simple job once you get in there, and as much as it pains me to say it, Britpart CVs are amongst the best on the market, perversely. Only Ashcroft's are better, and at five or more times the price. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 24, 2017 Share Posted April 24, 2017 12 hours ago, Peaklander said: Are you sure? My MOT centre says that UJs are not part of the test. Peaklander, I think you are right, nothing in the inspection manual: https://www.mot-testing.service.gov.uk/documents/manuals/m4i00000101.htm They do check for split CV gaiters, in fact any gaiter of any sort that could allow grease to escape appears to be part of the test nowadays... Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 24, 2017 Share Posted April 24, 2017 I think the CV boot check is only about ensuring that the brakes aren't contaminated and to prevent road surface contamination (particularly dangerous to motorbikes). Rubber boots on steering rod ends are another item that seems pointless, but on deeper reflection is about reasonable assurance that the rod end won't deteriorate rapidly prior to the next test and result in an uncontrollable vehicle. They don't care about transmission components like CVs and UJs as the test doesn't consider them safety critical. Of course,t hat's daft because a seized or flailing prop shaft is a big risk not only to that vehicle but to others, and even a contained CV or UJ failure could cause a major risk if it failed at a critical moment, like pulling out in front of fast traffic or on a crossing. Quote Link to comment Share on other sites More sharing options...
gerrymc123 Posted April 24, 2017 Share Posted April 24, 2017 On 4/23/2017 at 7:36 PM, Peaklander said: Are you sure? My MOT centre says that UJs are not part of the test. 100% sure as my friends Defender failed on the back prop UJ, I had the fail sheet in my hand, and it was I who replaced it. In saying that it was in a right state. Quote Link to comment Share on other sites More sharing options...
gerrymc123 Posted April 24, 2017 Share Posted April 24, 2017 14 hours ago, Snagger said: I think the CV boot check is only about ensuring that the brakes aren't contaminated and to prevent road surface contamination (particularly dangerous to motorbikes). Rubber boots on steering rod ends are another item that seems pointless, but on deeper reflection is about reasonable assurance that the rod end won't deteriorate rapidly prior to the next test and result in an uncontrollable vehicle. They don't care about transmission components like CVs and UJs as the test doesn't consider them safety critical. Of course,t hat's daft because a seized or flailing prop shaft is a big risk not only to that vehicle but to others, and even a contained CV or UJ failure could cause a major risk if it failed at a critical moment, like pulling out in front of fast traffic or on a crossing. If that indeed is the case then the MOT test in the UK mainland isn't as severe as the one in Northern Ireland because I can assure you I recently worked on a Defender the test center failed on a UJ due to safety concerns. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 25, 2017 Share Posted April 25, 2017 I can't see it in the inspection manual.... Quote Link to comment Share on other sites More sharing options...
gerrymc123 Posted April 25, 2017 Share Posted April 25, 2017 8 hours ago, Bowie69 said: I can't see it in the inspection manual.... Well it looks like the only way I can nip this in the bud is by producing a copy of the MOT failure with the UJ included as one of the faults but as it wasn't my Defender I'll need to contact the guy to see if he still has the failure slip. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 25, 2017 Share Posted April 25, 2017 Absolutely. Thing is, with MOT computerisation, unless it exists as an RFR then it is tricky to fail it, but we shall see Quote Link to comment Share on other sites More sharing options...
gerrymc123 Posted April 25, 2017 Share Posted April 25, 2017 I draw attention to "Other defects" and the last item on the list; Ma = Major Defect 1010 : Engine/Transmission : Transmission Joint - worn excessively - Rear That's the back UJ on the rear prop-shaft. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 25, 2017 Share Posted April 25, 2017 Never doubted you of course, but i guess this is one of those oddities between mainland and NI tests, presume maybe more in line with EU standards given your land border is invisible? I've heard some other stories about NI and Irish cars, insurance etc, so it doesn't surprise me it may be more strict over there. Quote Link to comment Share on other sites More sharing options...
