tjolliffe Posted April 28, 2017 Share Posted April 28, 2017 Hi All, I've got a pair of early type ashcroft CV's (and shafts) to fit to and early disco axle (although not got the axle yet). Ashcroft state that the stub will need a small amount of machining. Does anyone know where on the stub that machining is required? Can it be done with a grinder / dremel? Thanks Tom Quote Link to comment Share on other sites More sharing options...
neil110 Posted April 28, 2017 Share Posted April 28, 2017 From Ashcroft website. This type can also be fitted to early Disco I's but you will need to make a small machining mod to the stub for clearance, we are able to provide details of this for you. The overall length measurement is 236mm Quote Link to comment Share on other sites More sharing options...
tjolliffe Posted April 28, 2017 Author Share Posted April 28, 2017 Yeah I know, I've seen that, just want to know what the 'machining mod' actually is.. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted April 28, 2017 Share Posted April 28, 2017 58 minutes ago, tjolliffe said: Yeah I know, I've seen that, just want to know what the 'machining mod' actually is.. I suggest you follow the advice, politely emphasised already " ... we are able to provide details of this for you. ". Do we really need to write 'Phone or email Ashcroft's directly'? Or should we detect some previous bad blood between you and them, that makes personal contact unviable? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted April 28, 2017 Share Posted April 28, 2017 If you find out what needs doing I can probably help. Quote Link to comment Share on other sites More sharing options...
