Range Rover Blues Posted April 30, 2017 Share Posted April 30, 2017 (edited) Hi Guys. I'm replacing a cam belt that sadly has snapped. I know I should have done it before now but it was still within the mileage window, what I didn't know was that it was not done correctly! Anyway, the engine might have survived and I'm putting it back together but when i line up the pulleys the camshaft pulley wants to be half a tooth off from the timing mark. I remember this happening last time I did one, is it common? any advice of which way to let it fall? there's a photo in the tech archive where it looks to be retarder half a tooth? Any advice would be great, thanks Edited April 30, 2017 by Range Rover Blues Quote Link to comment Share on other sites More sharing options...
Sabre Posted May 1, 2017 Share Posted May 1, 2017 Align the camshaft gear to the alignment mark, then loosen the three bolts on the fuel injection pump gear, and turn it so that the belt slips over the pump gear. Assuming you have the flywheel and fuel pump locked in their respective correct positions ? Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted May 2, 2017 Author Share Posted May 2, 2017 Yes I bought the timing kit last time I did one. So the alignment mark is a starting position before the belt is fully tensioned. That makes sense, many thanks. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted May 4, 2017 Share Posted May 4, 2017 Then once it's on, loosen the bolts again and give it a very slight turn to the clockwise Quote Link to comment Share on other sites More sharing options...
Tobias Posted May 4, 2017 Share Posted May 4, 2017 9 hours ago, honitonhobbit said: Then once it's on, loosen the bolts again and give it a very slight turn to the clockwise 'It' being the FIP gear or the engine? Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted May 5, 2017 Share Posted May 5, 2017 the FIP pulley Quote Link to comment Share on other sites More sharing options...
