agarabaghi Posted August 8, 2005 Share Posted August 8, 2005 Well i was wondering if anyone knew which wireharness and where i could get one installed for the trailer lights. Can anyone do the install or must i take the truck to Land Rover dealer? Could a place like Uhaul do it? Thanks. Alex Quote Link to comment Share on other sites More sharing options...
Guest MJG Posted August 9, 2005 Share Posted August 9, 2005 It is a breeze to fit trailer electrics to a series II Discovery. If you remove the rear Drivers side (That is Drivers side in the UK) light cluster you will find a plug into which the std. Land Rover wiring kit plugs into....... There is enough space at the bottom of this cavity to get the wire through outside to the underside of the vehicle where you simply mount it with the supplied bracket. Quote Link to comment Share on other sites More sharing options...
