how to work out your diff ratio
is there a simple way of working out what ratio your diff is without removing everything on the front? was thinking there must be a way of measuring how many revolutions of the wheel you get per turn of the prop. any suggestions more than welcome. thanks.
If the rear diff is a known quatity (or one in another car for that matter) you could chock one side of the car then spin the diff noses and compare the number of revolutions of the road wheel for a given number of propshaft/diffnose revolutions
Lewis :)
sounds pretty good, the problem is ive got myself into a real situation. i blew the front on a play day. i then replaced this with another, i compared the old and new before putting them in and they looked the same (pretty stupid now i think about it). i put it in and went for a test drive on some green lanes. after about 1/2 hr the back blew which makes me think that either the rear was either severely weakened in the incident that blew the front or ive been a real dipstick and put the wrong ratio diff in the front. the only way to tell is to do what you suggested and compare it with another before i take it out of a donor vehicle. the problem im having is tracking down second hand ones. thanks for your quick reply.
The diff will most likely only be either 4.7:1 Series diff or a standard 3.54:1 and you should be able to tell the difference between them using the prop revolutions: 10 wheel revs will either produce 35 or 47 prop revs.
Counting the pinion and crownwheel teeth is of course the "correct" way but unless you have a "special" there are only two factory diff ratios and the vast majority of diffs out there will be the 3.54:1 which is what has been fitted in all 90/110/Defender, RR and Discovery vehicles.
Hope this isn't classed as highjacking a thread as on other forums.... I was just about to post a similar question, can you mix axles..?
I have a 98 110 TD5 bent rear axle, it looks to have tubes pressed into the diff housing, the 2nd hand one I just bought has a moulded all in one casing, if the ratios are the same I guess it can be fitted...?
If it turns out to be wrong and it will fit yours maybe we can help each other out here...??
Regards Dave
I have a pair of 4.1 ratio diffs from an ambulance, aparently a few 4.1 factory diffs were produced
That sounds like a Salisbury axle, only fitted on the back of LWB's from late S2 to late 110's. No you can't mix diffs from them as they're physically different to the Rover axles.
As for the original post, if it's a Range Rover, Defender or Discovery diff then it will be 3.54:1, I would think a Series one would be obviously different next to a coiler one as the ratios are different. Jack one wheel up and spin it to count prop revs, it's not rocket science. Everything coiler is 3.54:1, everything Series is 4.7:1 with the exception of Stage 1 V8 (3.54:1) and 101/FC which you wouldn't have one of anyway.
Regards Dave
further to Fridge's reply, so you've bent the axle housing and you want to swap another in ?
sounds like the one you have aquired is out of either a 90, Disco or RRC which is a Rover axle and no where near as strong as a Salisbury 8HA, which is what you would have in your 110. Also the pinion nose is shorter on the Rover housing, so the tail shaft will be too short to fit, although it will physically bolt in.
How bent is the housing ? Is it easier to straighten and repair it ?
A salisbury is cheap enough to find, they don't damage easily (I'm impressed you bent one) and you can make a drum-braked one disc-braked using off-the-shelf parts (search this forum for how). Pay no more than £50 for a salisbury axle, usual rate is about £30 as most people can't be bothered tripping over them / moving them out of the way :lol: disc braked ones may be a tad more but eBay & the forum classifieds are your friends ;)
not quite that cheap here.
at those prices, some enterprising soul over there should start buying them up and flogging them to the Yanks as lightweight Dana 60's :lol: Freight could be a killer, 'though :blink:
actually, I think the story went it was made under licence by GKN for Rover.
CWP is interchangeable, carrier bolts are 12mm instead of 1/2" UNF, I think the pinion bearing is slightly different and the pinion spline count is different.
Oh, and a Sals uses the weak Rover axle diameter and spline count. Axle tube diameter/wall thickness might be a bit lighter too.
Was all said very tongue in cheek.
Yanks wouldn't go for 'em anyway as a Sals is too narrow for their tastes. :lol:
Real story.........
The differential in question was designed by the Salisbury Axle Company, which was purchased by Spicer in the 1918. Spicer became Dana in 1946. The "salisbury" axle used in Rovers have a Dana Model 60 differential. The axle assemblies are built by GKN which has many close ties with Dana.
http://www.dana.com/centennial/timeline/early.shtm
  • 9 years later...
Only if you jack up the whole axle and spin both wheels.  If you just jack and spin one wheel, expect half that number of prop revolutions.
Think he probably fixed it or chucked it by now :wacko:
  • 1 year later...
guys can anyone help me i have a 1998 110 defender previously was a army v8 i have left the front axel in but a 300 tdi disco engine box and rear axel into it as it was on drums at the back ,its been getting built for some years took it for a spin around the block and it just dont seem rite i cant get it to pull away ive got to rev the nuts off it to get it to go and i am thinking the front diff could be an issue with it being off a v8 petrol i read on this post they are different could one of you landy chaps help me out as i am stumped.
cheers
cheers
Manual or auto?
@crewcab 110 said he'd put a Disco 300 engine + box in, if he swapped the transfer box as well that would make it 1.2:1 ratio where the original would be 1.4:1 so a bit more lively off the mark (well, a fair bit more lively with a V8 too), if it's pulling bigger tyres than a Disco (and most Defenders are) that won't help either.
That said, a 300TDi in a 90 should be able to get out of its own way.
I'm not so sure about his claim to have put a Disco axle under the back of a 110 as the 110 should have a Salisbury back axle, a Disco one isn't rated for the weight and surely the propshaft wouldn't meet up due to the diff pinion length difference :huh: there's something odd here.
  • Like 1
