Paul Posted June 22, 2007 Share Posted June 22, 2007 Some time ago I fitted a low coolant alarm to my Defender, and since my version is slightly different to some, I thought I’d share the ideas and reasoning. I’ve always had an issue with trying to detect a low coolant state either in the thermostat housing or the top radiator hose. When the engine is running, these are the two worst places to be looking for low coolant level because of the operation of the water pump. In our Land Rover engines, the water pump draws coolant in through the bottom radiator hose and pushes the coolant from this hose up through the engine and out through the thermostat housing into the top radiator hose. If the coolant level was low it will show up in both the radiator and the expansion tank, before a low level was experienced in the thermostat housing or top radiator hose (whilst the water pump is operating). It would only be when the pump was stopped that the low coolant level would be equal in both the expansion tank, thermostat housing and radiator. This is in fact done deliberately by most manufacturers to ensure that the engine receives its full level of coolant whilst in operation, even if the system is a little low. The low level is carried in the radiator, not in the engine. Only when the level is so low that it falls below the level of the water pump (causing the pump to cavitate) will the engine not be full of coolant whilst the pump is operating. As I said above, this is the system for the majority of engines. A very few have a reverse coolant flow where the thermostat is mounted below the water pump, and the pump pushes coolant down into the bottom radiator hose, up through the radiator and into the engine. In this system coolant level is ultra critical because any low level is carried in the engine (at cylinder head level) and the radiator will always remain full whilst the pump is in operation. The only example that comes to mind is the 12valve 2.4 Nissan engine used in the '90's in Pintaras and Ford Corsairs. I decided that the expansion tank is the most convenient of the correct places to install a sensor and initially went down the route of using one of those Range Rover caps that incorporated a level sensor. However, the Rangie cap sensor proved to be quite temperamental, so I searched for a more reliable solution. Enter the simple and effective float switch I discovered on www.4x4gadgets.com.au. This company sells the Little Black Box system which is very comprehensive, but I was only looking for the coolant level sensor. After a quick phone call I confirmed that the sensors were for sale separately (about $25 IIRC), and a plan was formed in my head. Here’s the coolant level sensor, a straightforward level switch, easy to install with minimal chance of gremlins: Installing the switch was easy, simply drill a 22mm hole in the side of the plastic expansion tank, screw in the sensor and wire it up: Here it is installed in my 200tdi Defender: Here’s one installed in a TD5: And another one in a Series II Disco: Next we come to the slightly more complicated part. The sensor is just a switch, and as it is it’d work fine in an on-road vehicle, but our vehicles may occasionally spend some time at a slight angle, or bouncing around a bit. This would inevitably lead to false alarms as the coolant sloshes around in the tank giving the sensor a hard time. Obviously what is needed is some sort of time delay. At this point my fellow Land Rover suffering mate, Pete, came to the fore. He put together a simple and robust little circuit from fairly commonly available components that achieves our objective i.e., a short (adjustable) delay before the alarm is triggered to prevent false signals when off road. Firstly, here’s a couple of photos of the completed circuit: Now, here’s the circuit diagram: Finally, here’s Pete’s description of the circuit for those of you who wish to replicate it: This circuit is setup to provide an adjustable delay from the sensor located in the header tank when the level drops. It works using a basic 555ic timer circuit. When the ignition source is initially turned on pin 2 is triggered via a short pulse from the C2 and R2 combination. This then allows C1 to charge via VR1 and R1. If the tank switch is closed (the tank is full) C1 is held to ground and a small current flows through R1,VR1 and the tank switch. This will remain like this until the tank switch is opened or the ignition is turned off. In the event that the tank switch opens C1 will begin to charge through VR1 and R1. When C1 gets to 60% of the ignition voltage pin 3 on the 555ic will be grounded causing Rly1 to turn on and sound the alarm. I also had to add a suppressor inline with the supply to prevent false alarms when heavy load equipment is started and stopped. This was typical fans and windscreen wipers. My setup was set for about 8 seconds of delay. The components I used were what I had laying around but seem to give a good range and do not draw much current through the tank switch. Component list R1 – 33k R2 – 33k VR1 - 1M C1 - 4.7 uf C2 - Green cap unsure but not that critical D1- IN4001 Rly1 - Standard 12volt relay Now Pete is a member of this forum and goes by the username of Peterla, so if you have any particularly techo type questions, either PM him direct, or PM me and I’ll pass them on. I guess the actual alarm is the final part of the puzzle. I simply used the output from the circuit to trigger a standard relay, which is in turn connected to a piezo buzzer and a light. The buzzer is tucked behind the dash, but is easily loud enough to be heard over the racket made by a 200tdi Defender at 110 kph. The light is mounted on the centre dash thus: There you have it. Simple, reliable and effective and it's been running in my Defender for some time now without issue. Paul Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 22, 2007 Share Posted June 22, 2007 Good post Paul ! Into the tech archive with this one methinks Mo Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted June 22, 2007 Share Posted June 22, 2007 I like the idea..... (But don't have the ability for the electrickery...) Anyone on the forums prepared to make and sell these? (Maybe make a contribution to the Gin fund as well ?) Sign me up for one...... Neil Quote Link to comment Share on other sites More sharing options...
reedx Posted June 22, 2007 Share Posted June 22, 2007 There is also another options using the Range Rover coolant level switch. Details on the following page http://forum.difflock.com/viewtopic.php?t=10972 Colin Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted June 23, 2007 Share Posted June 23, 2007 We fit about two 'little black boxes' a week. This consists of exactly the same float as shown above, and a black box that contains all the electrickery. It also gives an alarm on battery charge, battery level, coolant temp (programmable). We do export if someone in the uk wants one. Check out our website in my signature. The kit comes with installation instructions and is easy to fit. Here is the url to the workshop page: http://landyonline.co.za/workshop/index.html Quote Link to comment Share on other sites More sharing options...
rick Posted June 23, 2007 Share Posted June 23, 2007 nice post Paul. My intention was to adapt the RR cap, but this looks very good. thanks. Quote Link to comment Share on other sites More sharing options...
Anorak_Stan Posted June 26, 2007 Share Posted June 26, 2007 I Looked into this a while ago and decided to fit the Range Rover Coolant Sensor Cap (Even though it was relatively expensive) as when you look into the Specs of the Float switches they are not really suitable for The Pressure / Temperature iof the coolant system. LJC Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted June 26, 2007 Share Posted June 26, 2007 We have about a thousand people who would disagree with that, but never mind. Quote Link to comment Share on other sites More sharing options...
Paul Posted June 26, 2007 Author Share Posted June 26, 2007 My (limited) experience with the Range Rover caps is that they're rather unreliable. That's why I went off looking for a better solution. Paul Quote Link to comment Share on other sites More sharing options...
harle Posted May 20, 2008 Share Posted May 20, 2008 Just wondering... does anybody know why is there a diode running parallel to the relay? I'm just interested in how the circuit works. Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted May 20, 2008 Share Posted May 20, 2008 Just wondering... does anybody know why is there a diode running parallel to the relay? I'm just interested in how the circuit works. Yes, its to stop the back emf from the relay coil damaging the chip............. the back emf can potentially be many hundreds of volts, but in the form of a spike at very low current. the diode is often incorrectly referred to as a fly back suppressor circuit. All switched inductive circuits driven from solid state devices should have a protection diode. Ian Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 21, 2008 Share Posted May 21, 2008 www.4x4gadgets.com.au. Linky no worky. Quote Link to comment Share on other sites More sharing options...
harle Posted May 21, 2008 Share Posted May 21, 2008 Yes, its to stop the back emf from the relay coil damaging the chip............. the back emf can potentially be many hundreds of volts, but in the form of a spike at very low current. the diode is often incorrectly referred to as a fly back suppressor circuit.All switched inductive circuits driven from solid state devices should have a protection diode. Ian Ah i see, always useful to know stuff like that, thanks Ian. Thats pretty impressive at 12.30 am Quote Link to comment Share on other sites More sharing options...
Gromit Posted May 21, 2008 Share Posted May 21, 2008 My (limited) experience with the Range Rover caps is that they're rather unreliable. That's why I went off looking for a better solution. In what way did the RR cap fail? Did it fail open or closed? I've had one for about 8 months, linked to a Madman. No problems as yet. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted May 21, 2008 Share Posted May 21, 2008 In what way did the RR cap fail? Did it fail open or closed?I've had one for about 8 months, linked to a Madman. No problems as yet. The RR cap takes water into the base of the unit. Eventually the wire breaks leaving no connection. At least it fails safe. Well mine did. I did have a picture somewhere ?? mike Quote Link to comment Share on other sites More sharing options...
western Posted January 7, 2010 Share Posted January 7, 2010 another way to do it here http://forums.lr4x4.com/index.php?showtopic=49268 Quote Link to comment Share on other sites More sharing options...
wilber Posted August 25, 2010 Share Posted August 25, 2010 In my experience float sensors involve major surgery into the expansion tank and have a high early failure rate due to the high temperatures within the tank. The tank also has to be a "proper" pressurized tank that is a intregral part of the circulating system..Not just a expansion tank which stores expanded coolant and then draws it back on cooling. (you can lose all engine coolant and the level in the tank probably won't drop) The plastics involved in the floats construction need to be Glass filled nylon to withstand the temps/pressures involved....most floats are not made of this as they are designed to operate in a cold fluid enviroment (water tanks/waste tanks etc. Quote Link to comment Share on other sites More sharing options...
Red 110 Posted August 25, 2010 Share Posted August 25, 2010 Wilbur, I've had an EMS (http://www.littleblackbox.co.za/html/little_black_box.html) fitted to my TD5 110 for about six years now and it's probably saved me a serious amount of cash already on four occasions. It picks up coolant leaks very quickly (even when a radiator hose or the blanking plug at the back of the oil cooler fails) and shouts loudly. No problems with the float or expansion tank at all. Derrick Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 25, 2010 Share Posted August 25, 2010 I read somewhere recently, that someone offering aftermarket coolant level sensors have recalled/withdrawn them due to them not working properly. IIRC, a film of water could remain on the switch when the coolant level drops, thus not triggering a warning. Am looking for a solution for my TD5 tank at the moment... Quote Link to comment Share on other sites More sharing options...
alon666 Posted August 17, 2016 Share Posted August 17, 2016 Hi, new around here wanted to know what type of sensor is it. I found only plastic ones on eBay... A link for one would be great Thanks, Alon Quote Link to comment Share on other sites More sharing options...
mmgemini Posted August 17, 2016 Share Posted August 17, 2016 There is also another options using the Range Rover coolant level switch. Details on the following page http://forum.difflock.com/viewtopic.php?t=10972 Colin Suggest you look at he link here. That's the one I have fitted, the second prototype. Also that link may suggest other links. Suggest you read and digest them. Quote Link to comment Share on other sites More sharing options...
Dave W Posted August 17, 2016 Share Posted August 17, 2016 The Madman system I have just uses two stainless steel self tappers screwed into the expansion tank about an inch apart, has worked for 3 years so far without any issues and the warning light did come on the one time it was needed to ! Quote Link to comment Share on other sites More sharing options...
alon666 Posted October 13, 2016 Share Posted October 13, 2016 Paul, what is the value of C2 and what is S1 in the diagram? I'm building one right now and couldn't find out... Thanks! Alon Quote Link to comment Share on other sites More sharing options...
waterguy500 Posted September 20, 2017 Share Posted September 20, 2017 Hi Alon, I want to build the same circuit. Did you ever find the values of C2 and S1? If so, could you post them? Tom Quote Link to comment Share on other sites More sharing options...
Sean L Posted January 12, 2022 Share Posted January 12, 2022 Hi, I have recently bought an ex MOD defender 110CSW 2002 and have already decided to add a coolant level switch. Was initially going to use the range rover switch, and looked at some level switches. I have decided to go down this route instead: A replacement range rover sport coolant tank, with built in switch available on ebay, link below. I decided this option, as the whole unit is £23.90, so less than the cost of some switches, and my defender expansion tank is really dirty to the extent that it is impossible to actually see the water level in it! Doing this will solve all my issues in one go. Just have to blank off one of the hose connectors and need to work out a fixing method to install it in place. I will be doing this when the weather gets warmer and just thought I would share this as another option too 😎 https://www.ebay.co.uk/itm/173381541565?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D236212%26meid%3Dc4eaa1c95b15451b93c824a3ca80dde9%26pid%3D101195%26rk%3D2%26rkt%3D12%26sd%3D265069213891%26itm%3D173381541565%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv9PairwiseWebMskuAspectsV202110NoVariantSeed%26brand%3DUnbranded&_trksid=p2047675.c101195.m1851&amdata=cksum%3A173381541565c4eaa1c95b15451b93c824a3ca80dde9|enc%3AAQAGAAACEJOswHOSMq%2BLCgIiDVYOEzzOEJiTOODpTHNI45rQytazI%2FaJXd%2FxzMKBvFy%2Fw9uTO0Rvy%2BkUh%2FdHvhgnKXi07ZlLmaIPDGB5OPFTv3a7LSjWhfEtgNFIrfZJlI36HHZreSbqM3KMF5R1QNNAWyGmxAu5ebDD38KrY9%2BsIrYa4tv7Sj%2BSsuZ97dezhw47nqgVnB1BNn87y6T4bAgsREuTvHvKa0eITG1GjcPd4uEWWwnlQcavzB%2Fl4OCHFJ0NYR1L%2BqaPwpCYXmIpoCV7Fj9BYp6TTdn9jPdUO1XUe5zIyJa4hPXGvYT4tgz03Isgpw1nz7dlWGAvnu2rI0We8gNWUeGwedJa9T7QRSoHIlpNm1UvnWJe1UYEQL6G%2F85rrxFSqL%2FVftNSzkeUJbN7k9fgC4GeaBqBNi3uJhYDCSVvbg%2BSWOSVIziaBoIm0F9gBw2rCeVQusq3xOKjV6NhpwtJXUY5bUsJfy9nhsq3RYh6OJERccPyLw8Ok8LDXGINjpPAodPm0XXyKfTIM1wU2hVBajYoj%2FYoMJRDFjjbgxxCg0MqUaKzGfTqlQnYrMzZpFtyr%2BBfQBABcRYsZLVllds3PzxTq2tecGHq4YHRVub40FZOdnFcyRF0u%2B8o3BkfnKGnRWl%2FLvi6WZqrm83s35uSyl%2B0qQQLuMywqEpCeo%2BKuNKcrslxikoG3qiQYEmBsDIzwQ%3D%3D|ampid%3APL_CLK|clp%3A2047675 Quote Link to comment Share on other sites More sharing options...
