smudge Posted June 25, 2007 Share Posted June 25, 2007 anyone know what the correct tyre pressure should be for the front and rear wheels on my 1998 petrol freelander, standard wheels, cant find it anywhere on the net? many thanks Quote Link to comment Share on other sites More sharing options...
Llanigraham Posted June 25, 2007 Share Posted June 25, 2007 28 normal 30 fast or loaded LR used to say 32 but revised it later. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 25, 2007 Share Posted June 25, 2007 I thought it started as 30 then went to 26 but all I see is a manual with 30 in so maybe my memory is dud... Quote Link to comment Share on other sites More sharing options...
smudge Posted June 25, 2007 Author Share Posted June 25, 2007 jee wizz, i've been setting them all at 42, are you sure 30 is correct seems abit flat to me Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 25, 2007 Share Posted June 25, 2007 From the workshop manual TYRE PRESSURESAll driving conditions Front and rear 206 kPa (30 lbf.in 2 ) .............................. From the owners manual Tyre pressures - all models (up to 4 passengers and luggage)Front 1.8 bar (26 lbf/in2) Rear 1.8 bar (26 lbf/in2) Tyre pressures - all models (maximum Gross Vehicle Weight and towing) Front 2.1 bar (30 lbf/in2) Rear 2.1 bar (30 lbf/in2) From bulletin 0009 dated 3/3/99 MODEL/DERIVATIVE: Freelander CDS. ref: L8512buIssue: 1 Date: 03.03.99 AFFECTED RANGE: All derivatives PROBLEM: TYRE PRESSURE SPECIFICATION REVISED CAUSE: A revised specification has been introduced which reduces tyre pressures for normal driving conditions. Development has shown that this will enhance tyre life and improve ride comfort. ACTION: At the Pre Delivery Inspection and at routine service intervals, adjust the tyre pressures to the new settings below: Normal driving conditions (Carrying up to 4 passengers and luggage) Front 1.8 bar (26 psi) Rear 1.8 bar (26 psi) Maximum load conditions and / or towing (Up to maximum allowable Gross Vehicle Weight) Front 2.1 bar (30 psi) Rear 2.1 bar (30 psi) Please ensure that all Workshop and Service personnel are aware of this change. Workshop Manual Information will updated at the next amendment. PARTS INFORMATION: Yes I am sure Quote Link to comment Share on other sites More sharing options...
smudge Posted June 25, 2007 Author Share Posted June 25, 2007 what effect would this of had on my car, pumpin them up to 42, felt alot better to drive! Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted June 26, 2007 Share Posted June 26, 2007 Harsh ride, steers like driving on ice (especially in the rain) and wears out the centre of the tyre. 42 is seriously hard! I run my Rangies and Disco at 28 front and 30 rear unless towing when I raise the rears to 35. Quote Link to comment Share on other sites More sharing options...
jules Posted July 1, 2007 Share Posted July 1, 2007 These pressures work for stock tyres if your running BFG at's 36 psi is recomended any less will wear the outer edges I had all sorts of problems with LR dealers dropping the pressure and me not noticing. AT2's is what the misses is useing curently and we are impressed are about the same pressure as BFG's Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 2, 2007 Share Posted July 2, 2007 interesting, I run BFGs on my Discovery at well below the std pressures (25 front 30 rear) and they wear evenly! Quote Link to comment Share on other sites More sharing options...
MudAllOverIt Posted July 3, 2007 Share Posted July 3, 2007 interesting, I run BFGs on my Discovery at well below the std pressures (25 front 30 rear) and they wear evenly! When we had the Freelander we ran it with BFG MTs at 30 psi front and rear. No problems with uneven wear. Never had ATs on the Freelander so can't comment. Quote Link to comment Share on other sites More sharing options...
jules Posted July 4, 2007 Share Posted July 4, 2007 We were told 6psi above standard by BFG and after 60k on them we sold the car with the two that the dealer reduced the pressure it were still very leagul with 7-8mm just look very warn on both edges.. Quote Link to comment Share on other sites More sharing options...
Blippie Posted July 6, 2007 Share Posted July 6, 2007 We were told 6psi above standard by BFG and after 60k on them we sold the car with the two that the dealer reduced the pressure it were still very leagul with 7-8mm just look very warn on both edges.. Can vouch for that. Had a new set of BFG ATs last year and still wearing evenly at 36psi. Run the road tyres at 32psi. Cheers Blippie Quote Link to comment Share on other sites More sharing options...
jules Posted July 6, 2007 Share Posted July 6, 2007 When we had the Freelander we ran it with BFG MTs at 30 psi front and rear. No problems with uneven wear.Never had ATs on the Freelander so can't comment. My Dealer at the time it was about 2001 and the setting was 26psi which is what did the damage.. Quote Link to comment Share on other sites More sharing options...
smudge Posted July 10, 2007 Author Share Posted July 10, 2007 there seems to be quite a few different replys here, any of them correct, or that you would recommend, am just using standard wheels and tyres that are fitted with vehicle. Quote Link to comment Share on other sites More sharing options...
jules Posted July 11, 2007 Share Posted July 11, 2007 Only problems with the none standard tyres if you don't check up the manufacturers recommendations Quote Link to comment Share on other sites More sharing options...
