66gaza Posted November 8, 2007 Share Posted November 8, 2007 Where can I get some from, how much longer are they? how easy/hard are they to fit? I used to have wolf wheels and just put up with the fact the studs were a little short but now have some performance TX alloys and the wheel is thicker again and the nuts that are specific to this wheel just don't go on enough threads for my liking. So do I just need a lump hammer or a big vice or do I need a press to change them? Thanks Gaza Link to comment Share on other sites More sharing options...
Kev Baldwin Posted November 8, 2007 Share Posted November 8, 2007 Zeus Engineering Link to comment Share on other sites More sharing options...
Tonk Posted November 9, 2007 Share Posted November 9, 2007 zeus studs are fine, they are about 15mm longer than standard. to remove and replace just used a flypress or vice to press them out and back in Link to comment Share on other sites More sharing options...
streaky Posted November 11, 2007 Share Posted November 11, 2007 I got mine from Britpart....all 20 of them. They are about 15mm longer than standard ones and I have pictures to prove it. Part number FRC7577. Sorry I can't recall the price from about four years ago though. Fitting by way of a fly press is easiest as mentioned by Tonk. PS. I'm sure Britpart supplied hundreds of similar ones in the past so you can buy with confidance knowing that they fit. Link to comment Share on other sites More sharing options...
Les Henson Posted November 11, 2007 Share Posted November 11, 2007 I knock the old ones out with a hammer or mallet and then use the wheel nut to pull the new ones in. They are splined/interference fit. Les. Link to comment Share on other sites More sharing options...
western Posted November 11, 2007 Share Posted November 11, 2007 Those studs that Streaky has ^^^^ could be Series ones as their not in the electronic parts cat for Defenders. Link to comment Share on other sites More sharing options...
streaky Posted November 12, 2007 Share Posted November 12, 2007 Those studs that Streaky has ^^^^ could be Series ones as their not in the electronic parts cat for Defenders. I couldn't say Ralph. I bought the Wolf Rims from Britpart and asked them to supply the longer studs at the same time. My 130 was supposed to have the longer studs as standard but at some stage in it's life the axles were changes back to ones with shorter studs. Now I've sold the 130 I managed to keep the wolf rims and have put them on the Discovery. The studs are not quite flush with the face of the wheel nut...but I think they'll hold. (so far so good anyway) When I get a few spare quid I'll be going with the longer studs again just for peice of mind. S Link to comment Share on other sites More sharing options...
PaulMc Posted November 12, 2007 Share Posted November 12, 2007 Those studs that Streaky has ^^^^ could be Series ones as their not in the electronic parts cat for Defenders. FRC7577 - They're the longer (heavy duty) Defender wheel studs - listed for Defender XD (Wolf), Armoured applications and 130 - BUT, they don't appear in EPC, Microcat or the Defender XD parts book As far as I'm aware, the Heavy Duty 110, the 130 and the production XD (Wolf) all had (have) the standard wheel stud FRC5926 - and later - RUF000020 fitted. A single FRC7577 from a Land Rover dealer will cost you £15.85 incl. VAT - A considerably cheaper BritPart version is available. L. R. Series list the Genuine Part cheaper than a main dealer, as well as the BritPart version - http://www.lrseries.com/shop/product/listi...WHEEL-STUD.html Paul. Link to comment Share on other sites More sharing options...
western Posted November 13, 2007 Share Posted November 13, 2007 Cheers Paul, I've a full set [20] of FRC5926's at home & they are exactly the same as the Civvy sprc 90/110/130 studs & my 110's fitted studs. Link to comment Share on other sites More sharing options...
white90 Posted August 7, 2008 Share Posted August 7, 2008 http://forums.lr4x4.com/index.php?showtopic=29959 Link to comment Share on other sites More sharing options...
