treebloke
TD5 Clutch
29 posts in this topic
Changing the clutch on the td5 and the flywheel thingy is up the spout as well. Quite expensive arnt they :( .
Any idea what the toque setting is for the ring of bolts that hold the flywheel on? :huh: .
Share this post
Link to post
Bob , 110 Newton meters .
They are called Dual mass flywheels , DMF for short , and yes they can be expencive , but I think youcan by them as a set with the clutch for a cheaper price .
Get a quality make such as Valeo , LUK , and as a matter of course I replace the bolts as well.
Share this post
Link to post
Cheers Jase
We have just put a new clutch in the Unimog (now that is expensive) and the bolts on the flywheel for that are stretch bolts so I did ask them when I bought the flywheel but they said its ok to re-use them on the td5.
We will change the oil seal behind the flywheel, thats a tricky little bugger innit. Had a problem on the 300 tdi last time, just could'nt get it to go on right.
Share this post
Link to post
isnt the seal a bolt on unit on the td5s ?
Yes it is but it has two little holes in the base of the casting and you have to undo the sump bolts and drop the sump by approx 2 cms to get it over the crank case gasket, put the crank seal in place then tighten up the sump. Thats how we did it, dunno if everyone else does it that way.
What we should have done while we had the sump lose was take it off and put some lock tight on the five grand bolt, but time was against us so maybe over xmas.
We took the seat box out to gain access to the gearbox which is what we have always done with the 300 tdi but there are wires and cables everywhere on a td5, a right pain in the ass.
One thing we did learn was if you put a rachet strap under the gearbox, out through the doors and over the roof then attach the ends onto each other its perfect for winching up the box and quite easy to slide it all forward onto the engine. Much easier than messing about with jacks.
Share this post
Link to post
12 months on and I have a vibration, at first I thought it was the tyres or maybe a UJ but now I am thinking it might be the DMF because when you depress the clutch pedal, the vibration goes and with the cover off the battery box I can hear it coming from around the gearbox area.
Anyone else had DMF vibration.
Share this post
Link to post
I have never felt a DMF vibration on a Td5, but i have felt it on other cars and its quite often accompanied by a rattle or metallic knock! I find it hard to think that i could of failed in one year!
Ive never been a fan of DMF's so if it was me i would get a sprung centre clutch plate and fit a solid flywheel and do away with the dual mass system completely :):)
Share this post
Link to post
Is this possible with a td5 and if so, any idea who supplys them.
Share this post
Link to post
bob, i was reading on another forum the other day about these, apparently rakeway motorsport do them but they were expensive!
Ian
Share this post
Link to post
Ian
I was wondering about this too - my clutch is well on it's way. The DMF seems a dumb idea to me!
Is there not a flywheel from another engine which can be fitted - perhaps with a little machining?
Si
Share this post
Link to post
Birtpart do a DMF replacement with clutch for about £350
Rakeway do a replacement with cluitch for £1000
Or you can purchase a new DMF for about £150-200
Share this post
Link to post
That seems a lot! I wonder is a 200 or 300tdi clutch plate is the same diameter? Could one just re-machine the centre to attach properly to the end of the crank?
Si
Share this post
Link to post
It is a lot Si - i was thinking about one for the D-Lander, thankfully i no longer need one as i'm auto (altho that brings its own problems!)
Share this post
Link to post
Si
I have been to pick up the new clutch and none MFI flywheel (sorry Dual Mass) £350, for the lot. The thrust bearing has a longer shaft because the new flywheel is thinner than the DM.
I have an old 300 tdi in the yard, I will compare them before I fit it.
Share this post
Link to post
The vibration could be the spigot bearing - they are well known for wearing out. The last TD5 clutch I did, it just fell out. DMF's usually knock or seperate.
Les.
Share this post
Link to post
Les.
Did a forum search on spigot bearings and the only one that came up as this one :huh: .
I guess either way its the gearbox out. Is it a DIY job or would it have to go to somone like ashcroft.
Share this post
Link to post
I would say that doing the clutch on a TD590 is easier than a 200/300TDi 90.
Les.
No I meant the spigot bearing Les. I can do the gearbox in my sleep now.
Share this post
Link to post
On the last one I did, the bearing just fell out. The bearing is recessed a bit - the same as it is on any engine. They are generally awkward buggers to get out though and you usually have to break them up to get them out, so a sharp chisel/screwdriver will be needed
Les.
Share this post
Link to post
Les.
Forgive me if I appear confused but isnt the spigot bearing in the gearbox?.
Share this post
Link to post
no
the spigot bearing carries the end of the spigot shaft in the centre of the flywheel, the bit you have to line up reasonably well to get the gearbox back in
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
