maxtherotti Posted December 26, 2008 Share Posted December 26, 2008 he is a cutie why are they getting rid of him? rob Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted December 28, 2008 Author Share Posted December 28, 2008 I can't remember, they were fostering him or something and found a home for him, but he came back because the bloke who bought him got told off by his mum or girlfriend or something because they didn't approve. I think he is about 3 or 4 and is neutered. Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted January 25, 2009 Author Share Posted January 25, 2009 heater in place and connected up Patrol spring platforms cut off and Range Rover ones tack welded in place. Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted February 7, 2009 Author Share Posted February 7, 2009 Well guess what just DROVE out of the workshop. Ok so theres no exhaust, or body or, um, other stuff, but at least it runs! Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted February 8, 2009 Share Posted February 8, 2009 yeah well i,ve taxed worse rob Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted April 20, 2009 Author Share Posted April 20, 2009 another pic Quote Link to comment Share on other sites More sharing options...
callum Posted July 14, 2009 Share Posted July 14, 2009 your name came up in the for sale so i thought i'd ask if you've had any more progress. having it running is pretty cool at least. Quote Link to comment Share on other sites More sharing options...
discomikey Posted July 14, 2009 Share Posted July 14, 2009 nice build, i have only just discovered it, and have decided to follow it carefully from now on, im liking the drivetrain idea , much stronger than land rover axles, (mainly diffs) are they 4 pin? and i agree with the rangie body idea, i think it has that classic tradeamrk look. mikey Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted July 14, 2009 Author Share Posted July 14, 2009 HI Callum. Done nowt as been busy on other vehicles including my Plymouth However , I saw some nice old Rangies at the Ardingly show on Sunday so it gave me a little nudge to get back on it soon. Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted April 11, 2010 Author Share Posted April 11, 2010 Hi Mikey, not sure about pins, but the diffs are absolutely massive , as are the shafts, CV joints etc. Put it this way, NEVER heard of anyone breaking one, and that includes leaving it in 4WD with difflock on, on tarmac and turning it round with the tyres screeching. The propellor shafts are truck sized. M12 bolts for example and the flanges are about 4 inches diameter. The engine and gearbox are all cast iron and are basically ones used in small lorrys in other countries. The torque is good, and max torque is at 2,000 RPM. These engines have dual oil filters and dual batteries, and came in 12 and 24 volt versions. Inline and rotary pump versions too. Very tough. This is why Patrols 4.2 diesels go for so much money, even rusty old ones. They're just one of THOSE ENGINES. Can't believe I've not touched this project for so long, determined to do it THIS year. Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted November 6, 2010 Author Share Posted November 6, 2010 Got back onto this project after a long break mainly as I have a nice new workshop now and this is the first car to set wheel in it. I managed to obtain a rare turbo conversion manifold so I have been refurbing it. I just need to send the T3 turbo I have here off for rebuilding. Here it is with the inner wings off, ..taken the old manifold off, extracted a broken head stud, and done a trial fit of the turbo manifold and turbo. The downpipe I had for the turbo touches the bulkhead so I need to cut and shut that. Now all taken-apart-a-tated Been fitting a new clutch while the engine and box are out. Other jobs are to weld all the bits that are just tack welded, neaten things up, box in things that are just cut out (part of bulkhead etc) then get all the components sandblasted and repainted. Just to give you an idea of the build and torque of these engines, the clutch is held onto the flywheel with TWELVE 12mm headed bolts. (Propshaft bolts are 17mm headed) more take-apart-ing and fitting a return port for the turbo oil in the sump Pipe TIGged in, sump back on and engine painted. Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted November 7, 2010 Share Posted November 7, 2010 about time this beast got some more attention loving it so far!! Rob Quote Link to comment Share on other sites More sharing options...
bishbosh Posted November 8, 2010 Share Posted November 8, 2010 Now all taken-apart-a-tated Like it!! Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted November 12, 2010 Author Share Posted November 12, 2010 Bulkhead is back from sandblasting and primering so I've put some paint on it in my shipping contai... deluxe spraybooth. Chassis is at the sandblasters now. Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted December 28, 2010 Author Share Posted December 28, 2010 Got chassis back the other day Boxed in the bit I had to chop out of the crossmember. Then a coat of 2K black Also had front axle, calipers and swivel housings etc blasted and etch primed so I masked and painted these in the same paint as the chassis. VIOLA Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted January 8, 2011 Author Share Posted January 8, 2011 front calipers blasted, painted, rebuilt. fitting new swivel housing bearings, then checking preload etc. New halfshaft seals installed and new hub grease seals etc. New brake pipe, calipers and wheels on, radius arms bolted up, ready to wheel under the chassis! Axle rolled into place, radius arms bolted to chassis. Springs and shocks put in And panhard rod and steering box Thats it for today, looking a bit more like a vehicle now doncha think? Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted January 14, 2011 Author Share Posted January 14, 2011 I just noticed the number of views this thread has had! Quote Link to comment Share on other sites More sharing options...
Pete The Biker Posted January 14, 2011 Share Posted January 14, 2011 It's great work, so the number of views isn't surprising. Keep it coming! Pete Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 14, 2011 Share Posted January 14, 2011 Looks great . Can't wait to see the whole truck back together. Got an estimated finish date? Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted January 14, 2011 Author Share Posted January 14, 2011 hoping 2 months from now. Quote Link to comment Share on other sites More sharing options...
davie1 Posted January 14, 2011 Share Posted January 14, 2011 Well from the standard of work so far it looks like its going to be something special, great thread to follow. Thanks Davie Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 14, 2011 Share Posted January 14, 2011 Looks fantastic. If I see a high-riding Range Rover running about these parts I'll know where it's come from! Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted January 18, 2011 Author Share Posted January 18, 2011 Not trying to make it high, in fact the only reason it has any kind of body lift is so the engine doesn't hit the bonnet! Done a few more jobs, made a drag link for the steering, did some fabrication on the trans crossmember and some boring stuff like cleaning and painting various bolts and fasteners, made a fuel filter mount, and painted the other shock tower. Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted January 29, 2011 Author Share Posted January 29, 2011 Crossmember finished. Cue gearbox And an engine please Get them bolts in! Rebuilt Garrett T3 hybrid turbo please.. Cutting and shutting an old stainless downpipe to suit and tacking together. And a 1/8 npt boss for a pyrometer probe. Tig welded Installed, ready for next part of exhaust to be made. Bulkhead is dropped into place to check exhaust clearance. Nice to have the first bit of bodywork on. Time for a cuppa. Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted February 16, 2011 Share Posted February 16, 2011 time for the next update more like!!!! Quote Link to comment Share on other sites More sharing options...
