nickr Posted June 2, 2008 Share Posted June 2, 2008 Can someone tell me what each pin connection is for the rear wiper motor on a later defender (1995 onwards i think). The part number is AMR3676 and the motor has 2 wiring connectors with a total of 5 pins. The connector behind the motor is 2 pin and I have the existing connector which has a red and black wire, so I'm assuming this is the main power and earth. The connector at the top has 3 pins, I'm assuming these may control park and speed, but as i dont have the original loom I dont have any clues to the connecttions. I'd be grateful if someone could confirm for me please. Thanks Nick Quote Link to comment Share on other sites More sharing options...
western Posted June 2, 2008 Share Posted June 2, 2008 Wiring diagram for a 300Tdi rear wash/wipe below, might help you sort the connections Brown/Light green for washer Green = ignition controlled feed from switch for wash Black = earth for wash Red/light green to wiper motor from switch Black = earth for wiper motor other wiring diagram, should let you sort out your existing wires to the new motor Quote Link to comment Share on other sites More sharing options...
nickr Posted June 2, 2008 Author Share Posted June 2, 2008 Thanks Ralph, Those diagrams are certainly helping things. I've had a closer look and on my original post i said the 2 pin connector was red and a black, the red is actually the red/ green so corresponds to the 300tdi diagram and the connector c388-2. I'm therefore assuming that c079 refers to the 3 pin connector, but question now which pins correspond to c079-1 (bown/light green), c079-2 (green) and c079-3 (black). Iv'e taken off the cover of the motors and its not possilbe to see whats going on mechaincally to try to work it out. regards nick Quote Link to comment Share on other sites More sharing options...
western Posted June 2, 2008 Share Posted June 2, 2008 Yep C079 is the 3 pin plug. these 300Tdi rear wash/wipe connector diagrams should help too. Quote Link to comment Share on other sites More sharing options...
nickr Posted June 18, 2008 Author Share Posted June 18, 2008 Ralph, Thanks for the second set of diagrams, they have helped clear things up. Sorry for the delay in replying - have been busy at work and my home pc managed to get infected with malware making it unusable and needed rebuilting - not a very good example for someone who works in IT !!! Anyway I can now report, that to quote someone elses word in another thread somewhere " I have now made a pact with the devil as I have a working rear wiper!!" In fact I think I can now report that I have a 1985 ninety with all electrical circuits working - I probably did'nt ought to speak too soon!!! Thanks Nick Quote Link to comment Share on other sites More sharing options...
western Posted June 18, 2008 Share Posted June 18, 2008 Hi Nick, glad it all worked Quote Link to comment Share on other sites More sharing options...
