1 3/4" OD Former
bishbosh
Does anyone happen to have a former for a push bender that is suitable for 1 3/4" OD tube?
I need to put some very gentle bends into some CDS, something along the lines of 15 degrees I would estimate.
I have formers for pipe that are all ID so no good for my CDS tube.
Anyone got one I can borrow / rent for a weekend? Pretty please...?
Whata that in english bish? 42mm or 48mm or ??mm! i'll have a look.
Les,
So your former is for tube then? How bizzare! All the push bender formers I have seen that are stamped 1 3/4" are for the internal diameter so the external diameter is obviously bigger...... I have a 1 3/4" ID former in the garage... :
Jase, is your former 1 3/4 OD or ID as you are a tad nearer than Les.......
Les,
Its the former I have always used for 44mm pipe .
