The Megasquirt MegaThread MegaIndex
I've spent far too much time wading through Nige's excellent Megasquirt thread trying to find info that I know is in there somewhere. So here is an index. Actually, I only got to page 16 before getting thoroughly bored, but most of the good stuff is here.
Mods - is there an option to let me edit this and add more at a later date?
Nige's build
What is Megasquirt? Intro and Nige's build
Nige's PWM idle valve
Flapper to MS wiring diagram, AFM replacement, Custom loom manufacture
More devils knitting
RR in tank FP conversion
More loom, finalising bits 'n' bobs
Heater pipes
Finalising the loom
It won't turn off! Diodes and alternator wiring
Loom finalisation
More diodes and alternator wiring. Running stage.
Loom wrapping, tidying etc.
Waterproofing the MS box
Extra fuel filter, engine breather re-routing
Very smart chopped dizzy
LCD Dash
LCD Dash details/info/software etc.
Box for LCD Dash
So it is waterproof then...
Bling bling rockers, and the dangers of Bosch PWM vavles
LCD Dash upgrade to tablet PC
Starting improvements, PWM valve additon.
Other builds
landybehr coil mounts and wiring
Tuning
Nige's excellent tuning explanation
And BBC's notes on the above.
Narrowband VS Wideband
Timing advance on an RV8
Discussion of a valley in the spark table
Nige's tuning progress
Nige's further tweaks
Nige's explanation of MegaLogViewer and how to use it.
Further info on maximum advance on an RV8
Coping with large files in MLV
Nige's explanation of MLV v2.94 and how to tune: After start enrichment, Warm up Enrichment, PWM valve,
More on Nige with WUE, and Tuner Studio
Getting tuning software running on Win98
Explanations of stuff/Discussions
Megatune, EasyTherm, Megalogviewer and what it all means
Earths back to ECU
MS hardware and software versions, PC software and what they all are
Discussion of noise suppressing capacitors
How to make your own ignition leads/discussion therupon
Electrocution (or lack of) from a VR sensor
PWM Idle valves, setting up from BBC
Further thoughts on the above
Yes, more PWM valve advice from BBC.
USB/Serial adapter discussion, Maplin one OK
Spark/Fuel tables
4.6 Ignition map, TomG
BBC's Ignition map. 3.9? A bit whizzy.
BBC's 3.9 MSQ (Fuel and spark)
Nige's Eales maps, Safe and *ahem*...not so safe.
istruggle2gate11 Fuel and spark maps.
Megajolt spark table, 3.5 on carbs (John White)
Standard dizzy timing
Useful info
EDIS 8 ignition lead order
Alternating vs Simultaneous and AEnrichment
DIY Autotune's free software package
PWM idle valve, suitable donor vehicles/part numbers.
Settings for RR temperature senders, and .ini file
Bosch coolant and air temp sensors, part numbers
MS Pinout
Air temperature sender part number
Shopping list for MS'ing a V8
MS Extra 029v firmware, downloader, asm code and compiler
Voltages and pins on MS ECU/EDIS unit
:rofl: You defo need to get out more :rofl:
Most excellent :),
As for editing start a new post, PM the linky to me and I'll merage / alter :)
I will when I get a chance pop a note right of the front of the MS A-Z thread so this is "Known"
by all reading that thread early on :)
A Nice effort for all future and existing MSers :)
Nige
Since it was mentioned, I will point out the "official" paths of MegaSquirt info. However, due to the fact that MS is designed for ANY engine in ANY car, the information covers such a broad base & so many weird and wonderful options that I would strongly advise NOT reading it unless you need to, and instead following Nige's thread / searching on here as what works for one car does not necessarily work for a Land Rover. I have had to sort out a lot of problems caused by people doing things the MegaManual says which they didn't realise don't apply to them :rolleyes:
The official MegaSquirt manual - contains circuit schematics, build guide, wiring, sensor & injector info, basic tuning, troubleshooting etc.:
MegaManual
The official MegaSquirt forums:
MSEFI.com
Contains useful tech on setup, sensors, wiring etc., however most of you, if you've been paying attention, will be wanting the MegaSquirt-Extra forums:
MSExtra.com
Which are for anything relating to the MegaSquirt'n'Spark-Extra code that most people are running.
One that you should post on, if only for the benefit of others, is the "My MegaSquirt install runs" forum, otherwise known as:
MSRuns.com
(Incidentally, if you do post there I'd advise mentioning LR4x4 as anyone looking to MS their Landy would do a lot worse than to visit here and read up)
  • 10 years later...
