INDEX.* Read this Post before looking at any threads*
Some methods used may not be recommended
by other recognized official bodies,
but are non-the-less tried and tested methods.
If you feel that these methods are unsafe, then
consult other official bodies for an alternative method.
Always use correct axle stands and jacking/safety PPE
equipment before commencing work on/under any vehicle
POSTS YOU THINK NEED TO BE INDEXED IN THIS ARCHIVE PLEASE PM THE LINK TO ME --- Western,
then I can add it to the relevant section.
Axles/Brakes
Discovery 2 - The Three Amigoes
need to know wheel offset, PCD or centre bore sizes
Disc brakes for Series Land Rovers
Longer wheel studs for defender
Axle removal/repair
Rover axle shaft specs
Rear Axle removal and repairs
Steering guard bolt size
DIY tracking
diff pinion seal 300TDI Discovery
Ultimate Diff protector
How a Diff works
Defender Handbrake sticking
RR or Discovery 1 handbrake lever fit to a 90 or 110 Defender [1983 to 2016 only]
Diff ratios
ARB info/Fitting/electrics/fitment list etc
ARB Solenoids
ABS diagnostics 1
ABS diagnostics 2
ABS Brake bleeding
Freelander ABS sensor replacement
Bodywork/Chassis etc
A guide to Defender bodyside graphics
How to fit forward facing seats in a pre-Puma 90
Defender 2nd Row seat box
Defender Door Repair Project
Defender door frame repair guide
Painting info for LR body panels
200/300TDI engine mounts/chassis mounting
Rangie/Discovery Sill replacement
RR rear floor and cross member replacement
Chassis dimensions
Aide to under bonnet cooling
Discovery cage/bumpers/protection
Discovery window regulator replacement
Discovery rear quarter panel removal
Discovery1 clock removal
Defender dash upgrade
Defender Bulkhead compatibility
Defender body capping replacement
Defender Crossmember upgrades
Bulkhead Galvanising and prep using a TD5 on early models
Defender 2 part split rear door
Discovery 1 inner wing repair
Replacing Station Wagon side windows
Discover window lift repair
Range Rover/Discovery wheel arch trimming
Side window fitting in a Defender
Defender Windscreen replacement
Disco 2A headlamp bulb upgrade/fix
Disco2 leaking sunroof
Defender fuel cap upgrade
Defender Body Removal
Aerocatch flush fitting bonnet pins
Greasable, slop free, rebuildable Defender door hinges
90 V8 fuel tank removal
Electrics
Mirror Switch Repair, D1,RRC,FrLand, FORD!! etc
"supercharging" your heater
Bad earth fault finding
Vehicle towing electrics, LR start on page 228.
Fitting Advanced Alternator Regulator to 300tdi
How does the Alternator power the battery?
Engine will not turn off? Fuel cut off solenoid stays on. How to fix.
10AS Pin Out
Discovery 300Tdi bumper mounted rear lights
How to wire spotlights
12/24v stuff split charging etc
Useful wiring info
Carling switch wiring
Battery cut off
Low Coolant Alarm
Madman EGT Gauge
VDO gauge info
A127 magnetti marinelli Alternator reconditioning
wiring colours Land Rover
A127 alternator regulator replacement
Nanocom Diagnostics/Fault Codes
Defender rear wiper motor refurb
Definitive-rear-wiper-wiring-for-amr3676 or LR078424 in to a earlier 90 or 110.
Alarm spider/non starting/intermittent starting issues
Discovery 1 electric seat switch repair
Twin alternator set up
Twin Fan install
200TDI glow plug connections
200Tdi retro-fit info Disco ∨ R/Rover Classic 200Tdi into a Defender
Split charging
Heated rear window relay
Defender fan speed from 2 to 3 modification
Adding intermittent wash/wipe to an older 90-110
Variable Intermittent Wiper Modification
Defender intermittent wipers
Split charging 2
Dual alternators
Intermittent rear wash wipe on a defender
Intermittent rear wiper installation for Defender
Park brake warning light
V8 ECU problems
V8 HT Lead layout
Rover 4.6 P38 Engine Wiring Diagram, About to squirt a p38 lump
Electronic Ignition
300TDI alarm keyfob battery changing
Defender wiper switch internals and spring position
Alternator upgrades
Headlamp upgrades
300TDI wiring diagrams
How to replace wiper motor park switch
Hazard Switch & Indicators - fault diagnosis,
Defender heated front screen
The Definitive Alarm Spider Post
Defender/Disco/Freelander front wing side indicator repeater lamps
Extra front light switch & wiring for Td5 Defenders
Upgrading headlight wiring
TD5 fuel pump electric plug?
Td5 Gauges – Bulb Information
Td5 Speedo Mileage run up circuit
fitting Td5 dash into earlier models thread [wibbly wobbly speedo]
TD5 Dash install
new light for Td5 hazard warning switch
2nd alternator on a TD5
TD5 dash into earlier models connectors etc
TD5 Stater Solenoid Contacts
1999 model year Td5 wiring diagrams
TD5/PUMA central locking distance fix
Engines Diesel/Petrol/Gas
LR genuine 200tdi retrofit instructions
Replacing the starter ring at home
Changing 300 TDi valve stem seals with head on
300Tdi ROW fuel line fittings
Fitting a 300Tdi into a older pre Tdi 90 or 110
Replacing the Front CrankShaft Oil Seal - TIP
Bosch Injection Pump repair by Simonb
Oil pressure switches/specs
2.5 N/A head gasket replacement
Injection pump information
300TDi vin range/info re cambelt kits
300TDI water pump replacement
300TDI tappets adjusting/checking/setting
Auto oil cooler relocation
Tuning the 2.25
Megasquirt2
Megasquirt 3
Megasquirt tech
Megasquirt full install
Megajolt installation
Tdi Injection Pump Breather Leak
TDi injector spill return pipe issues
200TDI cambelt change
300TDI cambelt and kit 2
300TDI aux drive belt tensioner bearing change
sealing the 200-300TDI Airbox
Fitting a 200TDI Disco engine into a defender
Adding an intercooler to a S111
Fitting an EGT Gauge
EGT response times
200/300TDI tuning
VNT turbo info
Catalyst removal on 300TDI Disco/Defender
Td5 engine surging/turbo overboost
Waterproofing a V8
V8 Basics leads/cap/rotor etc
Stripping a Turbo
Cambelt failure reasons/suggestions
Injection pump seal replacement in situ
Injector removal
Dealing with a snapped spark plug
300TDI thermostat replacement
200-300 TDI head gasket Info
Series lift pump replacement
Adjusting tappets
Intermediate gasket
300TDI cylinder head removal
2.5 N/A timing belt replacement
Freelander 1.8 timing belt change
The proper way to build a V8 by Ian Bull Car Cowboy
Rover V8 - Head Bolts AND Inlet Manifold Bolts - order
200Tdi oil dipstick loose & LR Tech Bulletin on how to fix it
Fitting a 200Tdi hand throttle
300Tdi Vacuum Pump Oil Leak repair
Piston Failue.pdf
Gearbox/Transfer box/Overdrive/Underdrives
Roamer drive noise problem on a Defender
Speedo driver gear list
 TD5 auto XYZ switch stripdown
 LT85 20c solid case rebuilt
R380 Discovery box to Defender box- shifting mechanism
Freelander drivetrain
R380 rebuild
LT77 Rebuild
Slave Cylinder replacement
Slave cylinder push rod
Defender clutch change
TD5 and Late TDi master cylinder change
Identifying gearboxes
LT230 rebuild
LT230 leak fix without strip down
A-Z of gearing
Tip for fitting a Transfer Box
Options for reducing gearing ratios
Crawler box install
 GKN Overdrive - thoughts on
GKN overdrive fitting to a Defender
 GKN Overdrive Strip Down
Output shaft oil seal repair
LT230 front output bearing replacement
Adapting an LT77 to fit a V8
Testing a Viscous Coupling
Transfer Box Ratios
Discovery clutch change
Auto gearbox kickdown cable adjusting caution!
LT230 rear bearing and seal replacement
Bell housings
LT230 2wd conversion
X-Eng handbrake fitting to a defender
X-brake servicing
Freelander drivetrain set up
Manuals
Land Rover Manuals NZ website
MOD 90/110 TUM[HS] Manuals
101 winch PTO repair and overhaul manual
 manuals
Link for more manuals
GKN Overdrive owners handbook & fitting instructions
Delphi Lucas CAV DPS information
Microcat
Zeus tables
MOT Testers Manual
Individual vehicle approval [IVA] information.
IVA requirements
 V8 Flapper diagnostics
V8 hotwire EFI
Defender Water Ingress Manual
Misc
Webasto Thermotop C problems & a solution.
Fuel Injector Information
Defender Triple Wiper Upgrade
windscreen crank gear on a Defender
How to replace the lock barrel on a Defender fuel cap – pre TD5.
TD5 Fuel Cap Key
Veg Oil Install on A Defender TDI
Megajolt install
K&N Filters
Aluminium specs
Bandsaw blades specs/selection
Removing snapped halfshafts insitu
Defender Safari Snorkel template
Defender central locking install
Defender wiper upgrade
Eberspacher install in a 110
Defender heater checks
300TDI vacum pump repair
Faulty goods/bad workmanship/warranty issues
Mig welders/tips/advice etc
How can I assess the weldability of materials
Rivnut fixing -- [Video]
Sharpening drill bits
RR seat reset
Defender buying guide
Tool Sizes for specific jobs
Fixing/Servicing a Tubela tube bender
EPC with Windows XP
EPC Removal
EPC using Windows Vista
Good ideas
Conversion tables
Onboard air threads links
PDAs/GPS etc
PDA port splitter
Tyre valve protection
V8 Auto conversion
Intermittent rear wash wipe on a Defender
Welding Equipment
Setting up Radios and SWR on CB etc
Fitting a CB to a Defender
DVLA points system
Knots and all you needed to know about them
Spark plug info
Oil and filter change
Fuel filter change
TD5 fuel pump checking/replacement insitu
TD5 Defender 110 Auxiliary fuel tank
Fitting Helicoils
Discovery Dim clock display?
Drop arm ball joint
Stazwork double bead locks
Tubed/Tubless wheels and the difference
Cutom V8 exhaust
Viscous Fan operation
Disco 300TDI replacement for a 2.5TD into a Defender
Fitting Webasto Thermotop DW50 into a 90/110.
How to convert TDI to Veg oil
Propshafts
Prop shaft lengths
Disco2 prop on a defender(vibration) problems solved
Bespoke Propshaft for a 90
Propshafts and UJs
UJ replacement
Protection
Rollcage specs/Blue book
ALRC roll cage regs
Roll cages
Roll cage tube info
Welding a cage in a Defender
Defender storage lockers
Waxoyling
Front Diff guards
Strengthened cross member
110 station wagon internal roll cage install
Defender wing bars
Northoffroad wing bars
Recovery ideas/Equip
Recovery info
Recovery points
Tow straps
Strops etc
Recovery points
Mounting a high lift jack
Suspension/Steering
Mini Tech - How to set your tracking on your own !
rubber boots for steering ball joints on track & drag link rods
Overhaul of a 200 TDI Power Steering Pump
Hockey stick/Radius arm bush fitting
PAS box rebuild and mods
RR Eas valve replacement
Defender Suspension upgrades/Lift etc
Radius arm bush changing
Castor correction
Spring info
Dislocation/Relocation
300TDI PAS pump replacement
Shock absorber lengths
LR Suspension - Springs For All
Changing air suspension bladders
Steering wheels-what fits what
Steering gone stiff/tight spots lock to lock?
Replacing a V8 power steering pump in a 110
90 suspension upgrade
  • Like 1
  • Thanks 1
  • western unlocked and locked this topic
  • western unlocked this topic
  • western pinned this topic
  • western locked this topic
  • western unlocked, locked, unlocked and locked this topic
  • western locked, unlocked, locked, unlocked and locked this topic
This topic is now closed to further replies.
