Davecrx Posted November 25, 2009 Share Posted November 25, 2009 Hi to all. I've been searching all morning and i cant find what i'm looking for. I'm going to be putting a range rover 3.5 v8 running the flapper type efi system into my disco 200tdi. I just need a wiring diagram for the efi system so i know what wires do what when i'm installing the loom into the disco. Thanks Dave Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 25, 2009 Share Posted November 25, 2009 Quote Link to comment Share on other sites More sharing options...
evo828 Posted November 25, 2009 Share Posted November 25, 2009 Have you checked the pdf's that Nige has posted in Technical archive? Do not know if this is sufficient - but try it. http://forums.lr4x4.com/index.php?showtopic=16466 edit: FF was faster and more precise Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted November 25, 2009 Share Posted November 25, 2009 Off the top of my head IIRC you should have four wires on the EFI loom, you need to connect, Brown to permanent Battery Live White / Red to a Cranking Battery Live White to Ignition Battery Live White / Purple is the live feed to the pump……. Don’t forget to connect the multiple earths in the engine bay ………. Quote Link to comment Share on other sites More sharing options...
Davecrx Posted November 26, 2009 Author Share Posted November 26, 2009 Thanks for the help. Should be sorted now Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 26, 2009 Share Posted November 26, 2009 Plus fit a EFI Pump, use the top oif yours and the bottom of a RR earlyish one Nige Quote Link to comment Share on other sites More sharing options...
Davecrx Posted November 26, 2009 Author Share Posted November 26, 2009 Plus fit a EFI Pump, use the top oif yours and the bottom of a RR earlyish one Nige Nice tip. So i put the rr pump and housing in place of the tdi pick-up but still using the the tdi top part with the fuel connectors. Also as we are on the subject of fuel should i leave the sediment bowl in place of remove it? Quote Link to comment Share on other sites More sharing options...
