woolydisco Posted August 22, 2005 Share Posted August 22, 2005 Hi I have a 200tdi and the problem (well the one thats doing my head today) is that if I rev the engine while stationary when the throttle is released the revs drop to a very juddery 2/300 revs after about 5 seconds they pick up to a normal 6/700 revs also when on the road I come down the gears to stop it will also do the same when i cometo a stand still strangley enough it seems worse when pointing up hill I have changed fuel filter and put injecter cleaning fluid through it but to no improvement so was wondering has anyone else had this prob or has anyone got any ideas as to what i can check for thanx Quote Link to comment Share on other sites More sharing options...
Diesel Posted August 25, 2005 Share Posted August 25, 2005 What's it like at high revs? If holding back could be fuel line blockage further down maybe even in the tank, or air bleed into line from a dodgy joint or pipe How's starting? any different? Presume no excess crankcase pressure pointing to worn/stuck rings/major engine woes? Quote Link to comment Share on other sites More sharing options...
VERY OLD DISCO Posted September 26, 2005 Share Posted September 26, 2005 I had to turn my tickover up to about 850 RPM, or it stalls, check the adjuster screw is acting as the stop and the cable hasnt been set to short. Geoff Quote Link to comment Share on other sites More sharing options...
