Cranberry Posted December 21, 2009 Share Posted December 21, 2009 Can anyone suggest a good pair of blind spot mirrors for a 110 hard top - something that will remove the element of chance from leaving slip roads and overtaking? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 21, 2009 Share Posted December 21, 2009 Halfords, Yes Halfords do nice round ones. They stick nicely to the existing morror glass. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 22, 2009 Share Posted December 22, 2009 I've got some rectangular ones, also from Halfords. Only thing I've found is that you have to be careful where you put the nearside one, as the dash can restrict the view depending on where you have your mirrors Quote Link to comment Share on other sites More sharing options...
Cranberry Posted December 22, 2009 Author Share Posted December 22, 2009 I did pick up a pair of little mirrors from Halfords a while back - they help a bit, but I was looking for something bigger and better - my 110 is a hard top and LHD, so could do with all the help that I can get. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted December 22, 2009 Share Posted December 22, 2009 You are in a LHD vehicle; are you driving in a LHD country or a RHD country? We assume you are in a RHD country, the UK, but is that assumption correct? Where are you coming from, mirror wise in your 110? That is, what are you using now? Is the glass Flat or Convex? Regards. Quote Link to comment Share on other sites More sharing options...
Gavin Hatton Posted December 22, 2009 Share Posted December 22, 2009 I had a set of Ash Tree mittor heads and Hercules blind spot mirrors, they worked a treat. Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted December 22, 2009 Share Posted December 22, 2009 Gavin, Where did you get that set-up from? Thats rather brilliant & something I quite fancy. I have looked at Halfords for the little circular & rectangular ones, and optically they seem a bit rubbish. Could really do with a posh ser-up like that of yours. Martin Quote Link to comment Share on other sites More sharing options...
Cranberry Posted December 22, 2009 Author Share Posted December 22, 2009 Right - to clarify, as I should have done in the first post - I currently have allegedly convex glass in standard defender mirror heads - the glass I bought from Scorpion Racing and it is *slightly* better than the standard glass, but not that good. I have a LHD vehicle, and spend most of my time in Holland, but return several times a year to the UK - in both places my mirrors are decidedly lacking in terms of showing me what is to the side/rear of the vehicle. When driving in the UK I have a particular problem turning left or entering certain roundabouts - taking up the normal road position means I simply can't see what is coming. I suppose I am looking for additional convex mirrors to mount above/below the current ones - ideally something that could be mounted on the current mirror arms. Quote Link to comment Share on other sites More sharing options...
Lars L Posted December 22, 2009 Share Posted December 22, 2009 I solved the problem by putting in windows. But that might not suit you... Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted December 22, 2009 Share Posted December 22, 2009 Gavin, Where did you get that set-up from? Thats rather brilliant & something I quite fancy. I have looked at Halfords for the little circular & rectangular ones, and optically they seem a bit rubbish. Could really do with a posh ser-up like that of yours. Martin http://www.ashtreeglass.co.uk/catalogue/index.php Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 22, 2009 Share Posted December 22, 2009 Although it appears that I have Land Rover wing mirrors, they are actually LDV van ones. The convex glass seems better than the Land Rover one. They do have BRITAX mouled into them. I would have thought they would be the same mirror...I wonder if they are different. Quote Link to comment Share on other sites More sharing options...
leeds Posted December 22, 2009 Share Posted December 22, 2009 What size mirrors are currently fitted to your 110? If standard ones improved visability can be obtained by fitting larger mirrors Available on ebay HERE Can not remember which of the 4 x 4 companies do a large unbreakable mirror. Blind spot windows are available HERE HTH Brendan Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted December 22, 2009 Share Posted December 22, 2009 Cheers for that Nic. The website is pretty rubbish though...the applications listed under Land Rover are like old Series mirrors, and nothing like the one Gavin has used in the pics in this thread. I will fire off an email & get them to work out the product code for me. Gavin, any objections to me copying the pics in the thread to include with the email? Martin Quote Link to comment Share on other sites More sharing options...
reb78 Posted December 22, 2009 Share Posted December 22, 2009 Let us know the numbers. I'm interested too. Quote Link to comment Share on other sites More sharing options...
Gavin Hatton Posted December 23, 2009 Share Posted December 23, 2009 I got them from a friend who bought them from a place that is no closed but could be sourced from any Ashtree dealer. I had to replace the passenger side glass and after speaking to Ashtree they recommended Carlyle Bus and Coach Ltd. I imagine if you speak to them they'll be able to better help you. You'll need a different mirror arm to hold the large mirror heads that I had and the Hercules blind spot mirror (which I also had to replace at the same time) can be sourced here There's a range of glasses that the mirror heads can take. In the photo above I've got standards but when when replacing them I opted for convex to further improve visibility, all glass have the option of heated or non-heated. The Hercules blind spot mirror simply clamps to the main mirror head, so there's no chance it can fall off. I'll dig the mirrors out later and try to get a part number off of them to help you with your enquiries. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 24, 2009 Share Posted December 24, 2009 Can not remember which of the 4 x 4 companies do a large unbreakable mirror. Brendan X-Eng Quote Link to comment Share on other sites More sharing options...
pete3000 Posted December 24, 2009 Share Posted December 24, 2009 spafax unbreakable mirrors. a-la land rover wolf. can't remember the p/n off hand. Got some on my 110. Much better than originals. Plus you can twist them through 90 degrees if needs must to give a panoramic view. x-eng, mm4x4, lr-series, Pete Quote Link to comment Share on other sites More sharing options...
sas pinkie Posted December 24, 2009 Share Posted December 24, 2009 The wolf mirror heads are bigger and better in some respects. I have two wolfs, and have also found several down sides. These are: - Although unbreakable, they are still only a plastic mirror, so if used off road alot, scratch to beyond use quite quickly. - the way they mount does wear eventually, so they go all floppy on the stalks. Every time I have then tightend them up the thread rips out. - The design means that if you are tall (I am not but a good freind of mine struggles) the design means they cannot be angled up too high, reducing visibility. A few things to ponder. If you can get the heads cheap, then all well and good. I know of a couple of privately owned wolfs, where the owners had gotten so fed up they replaced the heads with standard defender heads. Quote Link to comment Share on other sites More sharing options...
shanghai1979 Posted December 25, 2009 Share Posted December 25, 2009 after driving my wifes pug 206 i'm very very pleased with the mirrors on my defender 90. Hardly any blind spots in comparison to the 206. I can hardly see when reversing with properly adjusted mirrors. The roof supports seemed to be modeled on church roof supports (too chunky) and mirrors modeled on dentists mirrors. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 26, 2009 Share Posted December 26, 2009 after driving my wifes pug 206 i'm very very pleased with the mirrors on my defender 90. Hardly any blind spots in comparison to the 206. I can hardly see when reversing with properly adjusted mirrors. The roof supports seemed to be modeled on church roof supports (too chunky) and mirrors modeled on dentists mirrors. I second that! Having driven a mates 90HT (standard mirrors), made me realise how bad the 206 mirrors are!! Quote Link to comment Share on other sites More sharing options...
