petrolhead63 Posted January 18, 2010 Share Posted January 18, 2010 well the factors are tryting to flog me all sorts of piddly little batteries! What should a 2000 TD5 manual have? I reckon something like a 110A/H 664 type if it fits the tray. Quote Link to comment Share on other sites More sharing options...
Naks Posted January 18, 2010 Share Posted January 18, 2010 What should a 2000 TD5 manual have? I reckon something like a 110A/H 664 type if it fits the tray. What is the CCA (cold cranking amps)? IIRC, with diesels, the highest cranking power you have, the better! Quote Link to comment Share on other sites More sharing options...
M&S Posted January 18, 2010 Share Posted January 18, 2010 My genuine battery is 110Ah/800A cranking Quote Link to comment Share on other sites More sharing options...
cipx2 Posted January 18, 2010 Share Posted January 18, 2010 The original battery is Delphi Freedom, 12V 110Ah, CCA 800A, Delphi part# 19001340, LR part# YGD100860 The motor factors tell you different because in nearly all aftermarket catalogs the Discovery 1.2 (the 300 series) appears as Discovery 2.. Given the engine capacity is the same, 2.5 liters, you will be adviced for a 72Ah battery, good for Discovery 300 series but not Td5. This was a mistake in the early catalogs which was transferred to the newer ones. Few catalogs have corrected this, Other say Discovery 2, 95-98 (or 94-99) which is ok. Quote Link to comment Share on other sites More sharing options...
petrolhead63 Posted January 18, 2010 Author Share Posted January 18, 2010 my usual factor searches by reg number and comes up for a TD5 wuith a 95 A/H battery with just under 700 cold crank. Its an industrial/heavy duty battery. This is still not up to LR spec...I have concluded I think a 664 which is 110A/H will fit and is a lot less than the orifginal LR one it seems. The posts will be to the rear of the battery box not central but that should be ok. Quote Link to comment Share on other sites More sharing options...
M&S Posted January 18, 2010 Share Posted January 18, 2010 This is what I have in mine, same as Cipx suggests: 2004 TD5 Battery Quote Link to comment Share on other sites More sharing options...
disco_al Posted January 18, 2010 Share Posted January 18, 2010 my lookup here suggests a 664 from 99-04, with an 072 (300 spec) as an alternative. Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted January 18, 2010 Share Posted January 18, 2010 I've just replaced mine and found the Delphi Freedom to be very expensive and hard to get hold of. I went with a Varta with a lower 85Ah, but higher 900CCA. The only issue was the Delphi's centre terminals, so I went for rear terminals, which fit fine. Quote Link to comment Share on other sites More sharing options...
