landroversforever Posted August 14, 2010 Share Posted August 14, 2010 Quality will live on for a lot longer than the hole in the wallet . Nige, we need pictures ... even if its a small part you've cleaned up Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 16, 2010 Share Posted August 16, 2010 Nige, we need pictures ... even if its a small part you've cleaned up Oi Ross!! this is a family Forum !! Keep it clean please!! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 16, 2010 Share Posted August 16, 2010 Surely the 'porn' part will keep them out and that's from a mod too Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 18, 2010 Share Posted August 18, 2010 We've built 4 [Edit: about 10 since you started] or so, does that count? Smart arse £1100 isn't bad. It certainly isn't cheap but you are getting quality..... Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted August 19, 2010 Share Posted August 19, 2010 We need more pics Nige My thoughts exactly! When I see the words 'V8 porn' I expect pictures! (ok ok - I realise it's early days yet - I can wait ) Also looking forward the day when this thread has a link to a YouTube "First Start" clip.. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 19, 2010 Share Posted August 19, 2010 Also looking forward the day when this thread has a link to a YouTube "First Start" clip.. Can't wait Nige, Any upgrades going in the firing line between engine and Simex? How about a nice set of 10 spline axles? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 19, 2010 Author Share Posted August 19, 2010 This weekend SWMBO is away, so with some luck I'll be in the workshop with Rags and Cleaning and polishing me pistons and heads Phnnnar Nige Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 22, 2010 Author Share Posted August 22, 2010 Righty Ho then - mini update Today saw me 'cleaning' some of the parts up for the start of the rebuild. Targets for today was the Trumpet Unit, and the Inlet Manifold and Pistons. When I say 'Clean' I mean clean, not a 'wipe with a Rag' and the "Thattado" stylee so many seem to think is clean, building an engine of any description, and / or espcially one in this state of tune is only as good as the condition and cleanliness of the parts used and similarly the cleanliness of the build itself. So My standard of "Clean is prob not what many would expect, nor indeed do, but it makes a HUGE Difference to the finished result and long life / performance of the rebuilt lump Also bear in mind the filtration on this engine had failed, and had drawn in dust - and highly abrasive dust too, this had coated itself to the Valves inlet trumpets etc in fact everywhere and if 100% of it is not removed then the rebuild would be a waste of time. My method is to 1st soak parts in the parts cleaner I have (been in their 2 weeks) then remove and scrub - toothbrushes are good, bear in mind its ali so you must not use anything abrasive - it takes time to soak into the stuck on carbon / dirt, and also you must not use things that ali doesn't like as you equally damage the soft ali. I then find that rags and Brake cleaner / diesel are good to get it off, plus a tin of FORTE Engine flush shifts some of the really stubbon carbon, sometimes it will come clean easily, sometimes its do what you can then resoak and do again, this what I have had to do with some of the pistons today - some will 'come up' next time, some may need a further soak, it shouldn't be rushed. This is the difference between DIYing it and having a so called garage do it fo you - no, they will just wipe bits with an oily rag, because your not prepared / or they won't clean things properly L:) As such the Trumpet base (which had to be fettled back into proper shapes as ding and dents and prev owners knocking and dented trumpets etc had taken their toll, and 1 trumpet even now (have asked re a new post in Int ) needs gluing back in - this trumpet alone was 2 hours work reshaping the trumpets etc and then , the inlet another 2.5 hrs to get proper proper clean at least I can get a 1.5 inch paint brush in the ports they are so kin huge ... and the pistons ....I have done 3... so still some to go : And thats this weekends worth of cleaning results When I have the rest of the Pistons done, then there are the heads, every bolt washer bracket flange etc is sitting in a 5 litre new Gallon Container of Kerosense and FORTE Engine flush, which I simply pick up shake and place another way up as I leave the workshoop each time I am in there, when I need to start the rebuild this just gets emptied and the contents re fettled, but will be 95% mint In the meantime block is away for liners check core plugs and cam bearings More soon Nige Quote Link to comment Share on other sites More sharing options...
jonost24 Posted August 22, 2010 Share Posted August 22, 2010 Looking good Nige!! As the old saying goes "If a job's worth doing...........get Nige to do it" Preparation is everything, whether it's your car or DIY on your house. As you know I'm going to MS my 3.5 bog standard. Do you think it's worth shortening the trumpets at all? I've heard that about 15mm off each one is about right, or do you think not worth the hastle on a bog standard engine. By the way thanks for the package , just in the process of planning my angle of attack. Don't want to dive in with both feet just yet Jon Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted August 22, 2010 Share Posted August 22, 2010 So a quick steam clean and reassembly with an impact wrench is not good practice? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 22, 2010 Share Posted August 22, 2010 Looks gorgeous :-) Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 22, 2010 Share Posted August 22, 2010 Looking lovely already! Nige, can you take some nice hi-res fancy-arty-pants-stylee pictures for my desktop please? cheers Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 22, 2010 Author Share Posted August 22, 2010 Nige, can you take some nice hi-res fancy-arty-pants-stylee pictures for my desktop please? cheers Can do Like - With a selection of beers and a takeaway in the background with some hob nobs strewn "Artistically" in the foreground ? Nige Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 22, 2010 Share Posted August 22, 2010 haha if you must Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 22, 2010 Share Posted August 22, 2010 Don't forget the jaffa cakes! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 22, 2010 Share Posted August 22, 2010 Nige are you remembering to wash your hands after each cake/buscuit? and before handling anything to do with the engine? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 23, 2010 Share Posted August 23, 2010 Do you think it's worth shortening the trumpets at all? I'd vote no - lot of hassle, and unlikely to do anything noticable on a stock lump. Quote Link to comment Share on other sites More sharing options...
jonost24 Posted August 23, 2010 Share Posted August 23, 2010 Cheers Fridge Jon Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 23, 2010 Author Share Posted August 23, 2010 ^^^ Sorry forget to reply TUP On a small bore V* (Less than 4.6) waste of time Shortening the trumpets makes the power shift up the rev rnage the 4.6cc has the grunt to mask the effects, do it on a 3.4 and things become very very revvy to get it to got Combo is shorter trumpets AN Bigger bores right through the manifold - but then you into serious money, and again the CC size bigger benifit more except I have seen a 3.4 Rover V8 (sleeved) with big bore trumpets shortened and it reved like nothing I has ever seen being over square Buit for the french events by JED so, answerr is NON Nige Quote Link to comment Share on other sites More sharing options...
jonost24 Posted August 24, 2010 Share Posted August 24, 2010 Cheers Nige Jon Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 1, 2010 Author Share Posted September 1, 2010 Picking Reliner re Cam bearing'd Block up hopefully Friday, along with new Big Ends, Mains And Ring sets. Have all 8 pistion now cleaned, Can Crank repolished and heads going together, so its coming along in direct proprotion to the £s leaving my account Pics and info coming soon(ish) Still cleaning front cover, and triple plenum cover, bought new Genuine Mains Bolts and Cross bnolts, John E advised repalcement (and genuine) as standard best rebuild practise Nige Quote Link to comment Share on other sites More sharing options...
will_warne Posted September 1, 2010 Share Posted September 1, 2010 Nige, so you are not using ARP main and x-bolts??? Are OEM bolts really up to dealing with the increased loads of a longer stroke, higher revving bottom end? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 1, 2010 Author Share Posted September 1, 2010 Nope A chat with Mr Eales has educated me that you shouldn't / can't fit ARP studs into a Cross Bolted block, the fact the mains caps are a snap fitmentment to the block means they would be an absolute *** to get on or off. JEs view is that new factory bolts set and torqued correctly are more than enough, its more the con rods (These are arrow rods with whizzy bolts) and head studs as well, where he DOES recomend ARPs, and so it will have them, wel actualy it does already Nige Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 3, 2010 Author Share Posted September 3, 2010 Just to add I am now a 'tad broke' Thats all, Nige PS But I do have a nice sorted block and other bits Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 5, 2010 Share Posted September 5, 2010 Broke... couldnt afford the bandwidth to put up photos? Quote Link to comment Share on other sites More sharing options...
