landrover598
Anti-roll bar
19 posts in this topic
I going to install an anti roll bar to my hardtop TDi defender and want to know where it would be most effective
Front or Rear axle ?
What do ya all reckon ? I'm going to have to make chassis and axle mounts so either one is as much work.
Share this post
Link to post
Fit a single to the rear, if on front it IIRC will give unpredictable steering feel.
Share this post
Link to post
Judging by the different thicknesses of the bars, the front will have the most effect.
Don't know if I agree with Ralph :o as plenty of vehicle only have front roll bars.. don't some discoveries have front only or am I making that up...?
Share this post
Link to post
all 110CSW upto the later models only have a rear one [on passenger carrying modles but not pick-ups/hardtops] my '89 110 does & no mountings for a front bar.
Discovery's have front & rear bars :i-m_so_happy:
Edited by western
Share this post
Link to post
Wolf's have front only (think the pulse 130" ambulance has both)
I won a 110 front bar off of ebay, not sure if i'm going to use it, it's missing one of the "U" shaped brackets, but if anyone wants it, they can have it for what i paid (£30)
Share this post
Link to post
The ''Twist Off Gone Wrong '' thread has got me wondering. If you took a Landy with a rear locker and front and rear anti roll bars attached up an articulation ramp until it lost stability (with a safety chain of course) and then repeated the attempt with both bars disconnected, would it lose stability earlier or later? My guess is that it would drive further up the ramp with bars disconnected before it did a'' Hummer''.
Share this post
Link to post
I'm not sure about the 90/110 variants, but i recall that in the press when the rangie's were first fitted with factory antiroll bars, the press blurb stated that "they only lost 1cm of axle travel"
how true this is, god knows! :lol:
Share this post
Link to post
On a side slope the anti roll bars would reduce the tendency to lean out of the slope and improve stability. Be a closer call on a ramp though as its forcing cross axle so everything else being equal (which it isn't) the f&r anti roll bars would work against each other but still improve stability up to the point (earlier) when the tyres break contact with the ground.
Share this post
Link to post
Old 110s had a bar on the back only, Dad's 1986 110CSW is like this, with the self levelling suspension unit (which doesn't)
Share this post
Link to post
Thanks for all the replies but i'm still none the wiser :wacko:
I'm thinking that the front might be the best, as with all that weight on the axle, it's less likely to lift a wheel :o
Share this post
Link to post
can i ask why do you want an anti-roll bar? its never going to handle like a car. most people i know who've removed them to improve flex dont seem to have noticed much difference anyway.
thinking back many years to when i thought tarmac was the thing to drive on i believe front anti-roll bars increase understeer & rears increase oversteer.
Share this post
Link to post
Dave, you're probably right. 110 tended to fit a rear one to reduce roll when heavily laden, ie more wieght in the back.
Is the roll that bad though?
Share this post
Link to post
As the landy is used as my road car for about 95% of the time, i'd like to improve the ride a bit, just fitted some softer springs and can notice the differece
They'll be disconnected for off road use so as to not affect articulation
Share this post
Link to post
The NAS was fitted as standard with both front and rear anti-roll or anti-sway bars.
The rubber bushes wore out, they reduced the axle articulation off-road and I did not find a ha'pence of difference when I took them off. However, with Rancho RS9000 adjustable shocks fitted to all four corners I can change the characteristics front to rear at the press of a button and get better articulation.
Go spend your money and waste your time on something more worthwhile!
Share this post
Link to post
Handling wise, if you fit a front bar, you'll get more understeer and fitting a rear bar gives more oversteer.
Fitting funky shocks will give better response to entering corners and leaving corners etc but you'll still get the same 'angle of dangle' in a long bend / big roundabout etc. It makes a huge difference to your confidence in the bend though.
Share this post
Link to post
I just fitted new shocks (ES9000) to the front yesterday :rolleyes: so won't be replacing them
Not had understeer before, but have had a bit of oversteer :o and a bit of rear wheel steer :o
Share this post
Link to post
Been driving a Series 1 V8 for many years and now a hybrid, my experience is I’d go for the front personally. Body roll in bends starts at the front in bends I believe, plus and more importantly, the reason that landies don’t stop in a straight line in an emergency stop is that the lack of front anti roll bar allows one side of the vehicle to dip first, this leads to steering geometry change and the vehicle goes veering off to one side.
Don’t know if anyone else agrees.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
