nickwilliams Posted June 1, 2011 Share Posted June 1, 2011 Apart from doing the rear wiper mod covered in another thread, I also sorted out the wiring for the intermittent front wipers. This information is all already in the tech archive but it's a bit spread out and so I've created this diagram which will hopefully allow anyone with an ounce of electrical knowledge to put the wiring together quickly and easily. This diagram shows the wiring which can be used to replace the intermittent wiper wiring loom, PRC8295. The original Land Rover part number for the delay relay is AMR2341 which gives a fixed delay of about 5 seconds between wipes and 4 wipes when the wash button is pressed. A Volkswagen 99 relay is a direct drop-in replacement for the AMR2341 and this gives a fully programmable delay between 2 and 40 secs as well as the wash wipe facility. Here is it as a PDF file: Intermittent front wiper.pdf 1 1 Quote Link to comment Share on other sites More sharing options...
western Posted June 2, 2011 Share Posted June 2, 2011 See this thread in Tech Archive too, http://forums.lr4x4.com/index.php?showtopic=927 Quote Link to comment Share on other sites More sharing options...
Litch Posted June 2, 2011 Share Posted June 2, 2011 I made my own harness up when I found PRC8295 was no-longer available and it worked perfectly but I spoke to Autosparks to see if they would include it in their list and thay have now added it, I ordered one a couple of months ago to replace my DIY one and it is fine (I wanted the relay block instead of separate spade connectors I was using). I posted this on the earlier intermitant wiper thread including the Autosparks part number. Quote Link to comment Share on other sites More sharing options...
western Posted January 11, 2015 Share Posted January 11, 2015 more info here http://homepage.ntlworld.com/stage1v8/Technical110FrontWiperRelay.htm Quote Link to comment Share on other sites More sharing options...
LØLØ Posted April 29, 2017 Share Posted April 29, 2017 Hello, thank you for this topic.I came from a french land rover forum, to solve a front wipers problème on a defender. I noticed an error on the original diagram on the principle of slow speed and fast speed. The color of the wires is reversed, do you agree with that ? While the diagram of nick williams is perfectly right and corresponds well to the observed operation. The link on my french forum directely on the topic: [url=https://www.landroverfaq.com/viewtopic.php?p=98617#p98617]Essuie glace defender td5[/url] On the other hand is that there exists the "flick wipe" function mentioned in the diagram of the PRC7370 ? Best regards Laurent ( LØLØ ) Quote Link to comment Share on other sites More sharing options...
western Posted April 30, 2017 Share Posted April 30, 2017 flick wipe only on the original non intermittent wipers, with intermittent wipers the down movement is to activate the intermittent function, the wiper stalks are different inside, you can just move the stalk down & back up to get the same action as a flick wipe Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 30, 2017 Share Posted April 30, 2017 If you use a VW 99 relay, a quick push on the end of the stalk gives a single flick wipe, holding it gives you wash / wipe. Mo Quote Link to comment Share on other sites More sharing options...
LØLØ Posted May 1, 2017 Share Posted May 1, 2017 On 30/04/2017 at 8:37 AM, western said: flick wipe only on the original non intermittent wipers, Hi, OK, it's mean, that there are more or less false plans since the 300tdi up to the last TD4, because the flick position appears on every symbol. Also what do you think about the colors of the 12V wire on the pin number 6 of C0278, I have never seen a WG colors I have allway see a NG colors. Do you know why ? Thank you for your answers. Quote Link to comment Share on other sites More sharing options...
ukspike Posted May 1, 2017 Share Posted May 1, 2017 I did the same as Mo, much less hassle. Quote Link to comment Share on other sites More sharing options...
LØLØ Posted May 2, 2017 Share Posted May 2, 2017 On 30/04/2017 at 3:37 PM, Mo Murphy said: If you use a VW 99 relay, a quick push on the end of the stalk gives a single flick wipe, holding it gives you wash / wipe. Mo Hello, Yes, it's depends on the duration of the impulse ordered by the pin T. You can also use other time delay relay instade of AMR2341 such as them show in the picture they all work in land rover. From left to right:NAGARES (Citroën, Peugeot, Talbot) ; CARTIER (Peugeot); LUCAS (Land Rover); SIEMENS (VW et Audi) . Quote Link to comment Share on other sites More sharing options...
LØLØ Posted May 2, 2017 Share Posted May 2, 2017 If you have a doubt on the time delay relay, you can replace it by a shunt, so you keep both speed and the automatic return. So you keep the connection between 53M and 53s as it show on the diagram on the VW relay. Quote Link to comment Share on other sites More sharing options...
LØLØ Posted May 2, 2017 Share Posted May 2, 2017 But, my truths question is: why, there is an error on the colors of the speeds wires, during more than 20 years? And are You all right with this diagnose ? Best regards. Laurent Quote Link to comment Share on other sites More sharing options...
tonydrover Posted January 22, 2019 Share Posted January 22, 2019 Looking at doing this mod to my 1986 90. Currently only has 2 speed wipers with push down once wipe (which doesn't work any more). Does the PRC 7370 stalk switch fit onto an older 90 steering column? The wiring I'm quite capable of (I'm an aircraft electrician) just not sure whether to order one of those stalk switches or use a separate intermittent switch. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted January 22, 2019 Share Posted January 22, 2019 Yes stalk is a direct replacement. Quote Link to comment Share on other sites More sharing options...
western Posted January 22, 2019 Share Posted January 22, 2019 18 hours ago, tonydrover said: Looking at doing this mod to my 1986 90. Currently only has 2 speed wipers with push down once wipe (which doesn't work any more). Does the PRC 7370 stalk switch fit onto an older 90 steering column? The wiring I'm quite capable of (I'm an aircraft electrician) just not sure whether to order one of those stalk switches or use a separate intermittent switch. My 110 is a 1989 model, this was a direct swap. Quote Link to comment Share on other sites More sharing options...
tonydrover Posted January 22, 2019 Share Posted January 22, 2019 Thanks guy, I'll just buy a new stalk then. bit easier. 1 Quote Link to comment Share on other sites More sharing options...
tonydrover Posted February 8, 2019 Share Posted February 8, 2019 not quite a direct swap. The matching wires in the loom don't match the same positions on the new switch connector. So I've had to modify the new switch so that they do. Gonna plug it all in tomorrow and we'll see what happens this time. Tried it before as a direct swap and the only thing that made the wipers move was pressing the washer Quote Link to comment Share on other sites More sharing options...
Dr0v3r Posted October 11, 2019 Share Posted October 11, 2019 On 2/8/2019 at 2:02 AM, tonydrover said: not quite a direct swap. The matching wires in the loom don't match the same positions on the new switch connector. So I've had to modify the new switch so that they do. Gonna plug it all in tomorrow and we'll see what happens this time. Tried it before as a direct swap and the only thing that made the wipers move was pressing the washer MOD been done a while now, don't get variable intermittent wipe though despite fitting a VW 99 relay. The other thing is, the wipers keep blowing the wiper fuse randomly. Wondering if I need a resistor in circuit somewhere. The only thing that's different electrically is the newer wiper switch. The relay is only used on intermittent and wash/wipe. Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted October 12, 2019 Author Share Posted October 12, 2019 If you are blowing the fuse repeatedly then something is wrong, probably with the motor or the switch. I'd recommend sorting that problem out before trying to troubleshoot the intermittent function. There is no need for any resistors in the circuit. Don't assume that the switch works properly just because it is new, especially if it came in a blue box. Likely failure modes include loose terminals or bits of swarf inside the switch mechanism. Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 12, 2019 Share Posted October 12, 2019 Have a look at Smartscreen. They do a little box that will give variable intermittent wipe and also three wipes after pressing the washer jet pump switch. No new switches or relays required and very easy to wire in (with instructions). Quote Link to comment Share on other sites More sharing options...
western Posted October 12, 2019 Share Posted October 12, 2019 https://www.smart-screen.co.uk/product-page/smartscreen-intermittent-and-wipe-on-wash Quote Link to comment Share on other sites More sharing options...
tonydrover Posted October 12, 2019 Share Posted October 12, 2019 4 hours ago, nickwilliams said: If you are blowing the fuse repeatedly then something is wrong, probably with the motor or the switch. I'd recommend sorting that problem out before trying to troubleshoot the intermittent function. There is no need for any resistors in the circuit. Don't assume that the switch works properly just because it is new, especially if it came in a blue box. Likely failure modes include loose terminals or bits of swarf inside the switch mechanism. Just measured the current with the multimeter, it pulls around 4-5A, that shouldn't blow the 10A fuse. Measured the circuit resistance from the fuse and it's 1.6ohms. That works out at 7.5A on 12V, so again shouldn't blow the fuse. I'm wondering if you are correct with your dodgy switch theory. Maybe sometimes the switch causes it to draw more. Switch is the only bit that's different to before. There's the relay too, but it only uses that on intermittent. Quote Link to comment Share on other sites More sharing options...
