TheRecklessEngineer Posted June 12, 2011 Share Posted June 12, 2011 I've been looking for a selection of Poly-V belts for power transmission. I'm using some poly-V pulleys from various vehicles (Power steering and alternator pulleys mostly) - however, they seem to have the same pitch and width as an old 300 TDi discovery belt I had lying around. However, it needs to be loooong (nearly 3 meters in fact), so a standard automotive belt won't do. None of the usual places I'd go for engineering components (RS, Bearing Boys etc) seem to supply poly-V and I can't find much information about the various profiles. In fact, about the only thing I've found is this: My link Am I missing something here? Are they under some name other than 'Poly-V'? Anyone know where I might find them online? Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted June 12, 2011 Share Posted June 12, 2011 I recently had to source some belts and pulleys for a final year project (needed to gear-up a DC motor spinning at 1500RPM to ~16000 RPM to test an alternator). By chance I came across Challenge PT (Power Transmission) through a local distributor - David Harris of Whitland and although Challenge PT were less than helpful (borderline rude) when I tried to speak to them directly on the phone they do have a huge catalogue of parts (pulleys from <100mm to >1400mm any type of V-belt / Poly-V belt etc, motor mounts). I would be suprised if they don't have something suitable - the PDF version of the catalogue can be downloaded from here: http://challengept.com/flipcatalogue/files/ChallengeTechCat2011.pdf (bear in mind that it's pretty big - ~70MB). The challenge (no pun intended) might be in finding a distributor local to yourself. If you do struggle then I can dig out the phone number for the distributor where I got my pulleys and belts from (West Wales) and they're usually more than helpful so in the worst case scenario might be able to post things to you. Quote Link to comment Share on other sites More sharing options...
zardos Posted June 12, 2011 Share Posted June 12, 2011 You could try some searching on a belt manufacturers web site like Dayco Their part numbers have length encoded in them e.g a 7pk2250 is 7 v's wide and 2250mm in length or you could try contacting them linky a quick search gives a 7pk at 2875mm is the biggest I've found Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted June 13, 2011 Share Posted June 13, 2011 Forgive me if I am teaching my grandparent etc. but bear in mind that belts are spec'd by their circumference, not the distance between the the pulley centres (for obvious reasons). Hence, if you need a belt to drive something like 3m away then you will need a belt which is more than 6m long. I've found Brammer (what used used to be BSL) in Sheffield helpful and willing to get specials made for me in the past. They have depots all over the place. Nick. Quote Link to comment Share on other sites More sharing options...
61a Posted June 13, 2011 Share Posted June 13, 2011 I use a company in Kent called Ashford Power Transmissions Ltd for odd sized belts for my woodworking machinery. Always a fast service and excellent prices plus an enormous range of sizes for just about ever machine you have ever come across. Well worth a look on their website or giving a call. Another good thing is they don't sting you for delivery . Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted June 13, 2011 Author Share Posted June 13, 2011 Thanks for the help chaps. Never thought to check out belt manufacturers... The distance between centres is actually only about 1m, but one pulley is enormous (900mm) and there are two small ones to drive as well as an idler. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted June 13, 2011 Share Posted June 13, 2011 I'd suggest Brammer or Eriks. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted June 15, 2011 Share Posted June 15, 2011 I converted a lathe to inverter+polyvee belt from a variable speed vee belt thing. I got the parts from Power Transmission Supplies,Higginshaw Lane Oldham 01616260229 sales@pts-oldham.co.uk. Very helpful guys, like you I couldn't find much in the catalogues, they got the belt, pulleys and taper lock bushes. Fenner used to publish catalogues showing the calculations, and I attach my copies of them(I think). Incidentally I like the polyvee very much, very quiet,plenty of grip. Washing machines tend to use a tiny motor pulley and an enormous drum pulley, if you need to find a pulley cheap. friction_polydrive.pdf friction_polydriveribbed.pdf Quote Link to comment Share on other sites More sharing options...
simonr Posted June 15, 2011 Share Posted June 15, 2011 Redhill bearings near Horsham have been very helpful to me in the past and keep a good stock of belts. Si Quote Link to comment Share on other sites More sharing options...
Christophers1247 Posted June 21, 2011 Share Posted June 21, 2011 Hi Any commercial vehicle motor factors like dingbro or fleetgaurd should have poly v belts to suit as many HGV/Plant/Forklifts use long V belts for running there ancillaries. Failing that a company that supplies parts for industrial woodworking machinery. Quote Link to comment Share on other sites More sharing options...
