karlos01 Posted August 24, 2011 Author Share Posted August 24, 2011 it is only on the edis so it could be that? but mine does sound pants compared to that toyota jobbie Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 24, 2011 Share Posted August 24, 2011 If it's *only* on EDIS then te timing will be in limp-home mode fixed at 10deg. Quote Link to comment Share on other sites More sharing options...
karlos01 Posted August 24, 2011 Author Share Posted August 24, 2011 yes that is what i was refering to. its not got the smoothness like that toyota v8 so until i wire in the MJ i think it will run like that Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 24, 2011 Share Posted August 24, 2011 The Rover 8 will never sound as smooth as more modern lumps, partly due to age of design but also due to the firing order being different than "normal" V8's. Quote Link to comment Share on other sites More sharing options...
karlos01 Posted August 24, 2011 Author Share Posted August 24, 2011 has it got an odd sequence or something like that? do you think it sounds relatively normal in that case? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 24, 2011 Share Posted August 24, 2011 Strange, that Yota V8 has the same firing order as a RV8 I still think, at idle, which is ~ 10 BTDC anyways, it shouldn't sound like that. It takes 5 minutes to check the plug leads are in the right place, I would do that first if I were you.... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 24, 2011 Share Posted August 24, 2011 RV8 is different to things like the Chevy / LS engines hence why they're that much worse in water (cross-firing is easier on a Rover) and why they don't have quite the same sound (that and being half the displacement, natch) Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 24, 2011 Share Posted August 24, 2011 Engine defo does not sound great but is that headers / not a full zorst ? If so Rover V8 need a full system and back pressure and sound like **** if run on Y piece or just manifolds ? Although its a long time since I had Megajolt, seemed to remember a Vacumn hose for advance ? Nige Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 24, 2011 Share Posted August 24, 2011 You can build MJ for TPS and/or MAP sensor operation. Quote Link to comment Share on other sites More sharing options...
karlos01 Posted August 25, 2011 Author Share Posted August 25, 2011 its straight out of the manifolds at the mo. it was a shakedown to see if it actually worked before i smashed it to pieces Quote Link to comment Share on other sites More sharing options...
