Cyberfarmer Posted October 25, 2011 Share Posted October 25, 2011 Hi to all! I`m trying to fix a central door locking issue with a 03 Range Rover L322 4.4 V8. Btw, I`m using an Autoland Scientech Scanner to diagnose the L322. Here is the timeline before the central locking and the key fob stopped working: 1. The alternator died thus draining the battery 2. Replaced alternator and started the unit w/o faults 3. Key fob stopped working even if reprogrammed by the ..."press lock button while pressing the unlock thrice...." 4. Central lock button stopped working as well. 5. All electronics are working except central door lock. 6. Run through diagnostic and used an ACTIVATION MENU for each door lock, the only NOT working is the front driver side Door lock. 7. Used key to check open/close of door locks through key barrel but still NOT successful. 8. Opened door card and replaced Door Latch Assembly with a NEW unit. 9. Again, run through diagnostic and used an ACTIVATION MENU for each door lock and still front driver side door lock not working. (when switching on and off, I could feel the motor inside Door Latch Assembly moving a little but not full) Is this a BCEM problem now? Please Help. Thank you very much Quote Link to comment Share on other sites More sharing options...
Cyberfarmer Posted October 28, 2011 Author Share Posted October 28, 2011 Hi! The Range Rover is in TRANSPORT MODE. Anybody knows how to disarm it? I cant clear the fault. Thanks Quote Link to comment Share on other sites More sharing options...
