fozsug Posted March 23, 2012 Share Posted March 23, 2012 Came across this of Rasta 4x4 web site, its in Hebrew but you will get the picture when you see the video.!!! http://www.4x4.co.il/ArticleFiles/Video/RASTA%204X4_1.wmv Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 23, 2012 Share Posted March 23, 2012 That's pretty neat Folds away very small to. The youtube version is here Quote Link to comment Share on other sites More sharing options...
Richy B Posted March 23, 2012 Share Posted March 23, 2012 Yep, challenger 4x4 keep um in stock Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted March 23, 2012 Share Posted March 23, 2012 Made one on a similar principle as a motorbike stand about 25 years ago! Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 24, 2012 Share Posted March 24, 2012 Jimme three jacks doesn't quite have the same ring.... Quote Link to comment Share on other sites More sharing options...
calle-fas Posted March 25, 2012 Share Posted March 25, 2012 I like that for one reason. I usually change tires on site before offroading. It seems a lot easier than using the Hi-Lift. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 25, 2012 Share Posted March 25, 2012 Is it still as effective when the tyre in question is flat? You'll need to get the axle high enough to ensure the (hopefully) inflated spare will clear the ground. Same issue when swapping from road tyres to comp tyres too. Quote Link to comment Share on other sites More sharing options...
Henry Webster Posted March 25, 2012 Share Posted March 25, 2012 Quite neat, but how much easier is this than a standard LR bottle jack? Quote Link to comment Share on other sites More sharing options...
western Posted March 25, 2012 Share Posted March 25, 2012 or a trolley jack, at least it'll lfit a vehicle with a complete flat tyre. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 25, 2012 Share Posted March 25, 2012 Providing it doesn't start to slide on the ground I see no reason it couldn't cope with a fully flat tyre or with putting larger tyres on. It also has the added bonus of being really low tech and won't suffer from seal failures or lack of oil, so you should probably be comparing it to a hi-lift jack or some other mechanical jack to be fair. Quote Link to comment Share on other sites More sharing options...
