Les Brock Posted April 7, 2012 Share Posted April 7, 2012 Hi Guys, anyone got the proper width opening measurement ? Finally about to put the body on to the chassis. So whats the best way to allign everything, start at the rear tub rear mountings and go forward and then adjust the bulkead with washers if required to get the correct opening ?? I would measure the doors but I aint got any Ta ! Regards Les Quote Link to comment Share on other sites More sharing options...
ejparrott Posted April 7, 2012 Share Posted April 7, 2012 Bolt to rear tabs with no shims, see where front lands, fit bulkhead no shims, see if the door fits......except you havent got any shim bulkhead as required, shim rear of tub if required. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 7, 2012 Share Posted April 7, 2012 You need to get some doors really. Land Rovers being how they are I wouldn't like to assume that two sets of doors would be exactly the same width. A few mm longer or shorter and it'll mess up your door gap. Methodology as posted above, though if you're lucky enough to have the Td5 adjustable rear tub mounting rail that can make alignment a lot easier as you've got more adjustment at the back without using a load of shims. Quote Link to comment Share on other sites More sharing options...
Maverik Posted April 8, 2012 Share Posted April 8, 2012 hmm, from taking my truck apart the only way to get all your panels alignmets right is to "loosly" bolt everythig and then just start tightnening things up... its an absolute nightmare. Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted April 9, 2012 Share Posted April 9, 2012 I had the same problem, no doors. I measured a load in the carpark at Newbury sortout and they were all 865-870mm long. I've set my gaps to 880mm, I haven't fitted the doors yet........................ Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 10, 2012 Author Share Posted April 10, 2012 Hi Chaps, Thanks for the replies, I was only after a "guage" measurement to give me somewhere to start the process from... 880mm it is then (to start) Really looking forward to trying to get it all straight Regards Les Quote Link to comment Share on other sites More sharing options...
ejparrott Posted April 16, 2012 Share Posted April 16, 2012 I need to sort Kettle out, it appears the O/S of the new tub is about 12mm longer than the N/S. The old N/S door fits no problem, the replacement O/S door is nowhere near fitting, its currently got 3 M12 washers pushing the bulkhead forward of its outrigger and still needs more, and the top really needs pulling forward so that the roll on the door lines up at the back. I've got no shims on the mount tabs. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted April 16, 2012 Share Posted April 16, 2012 Did this yesterday Les. My doors (early 110 lift up handles) measure 865mm and I set the gaps to 875. Trial fitting the doors gave a nice 5mm gap parallel all round. 880 will only increase gap by a couple of mms all round and will give a bit more tolerance so would be a good start point. You won't be changing it once you start bolting other stuff on! Quote Link to comment Share on other sites More sharing options...
