mikec Posted June 11, 2012 Share Posted June 11, 2012 Hi I replaced my bust cv at the weekend now when I took the old cv off the shaft there was a spacer slid on the shaft before the cv, I presume it wasn't part of the cv. Has anyone got a parts book that can confirm the spacer goes there as I've put it together and forgot to put it back, oops! Only think I can think it stops the cv going too far onto the shaft? Cheers mikr Quote Link to comment Share on other sites More sharing options...
western Posted June 11, 2012 Share Posted June 11, 2012 see item 4 on page 414 http://www.retroanaconda.com/landrover/parts_books/110/5_axles_suspension_steering_p398-471.pdf Quote Link to comment Share on other sites More sharing options...
mikec Posted June 11, 2012 Author Share Posted June 11, 2012 Cheers for that pal. Do you know what nsp means in the remarks? Quote Link to comment Share on other sites More sharing options...
western Posted June 11, 2012 Share Posted June 11, 2012 nsp = not seperate part IIRC. so it's part of the complete CV joint, BUT on page 414 item 4 the same spacer for 110 with rear drum brakes gives 2 part numbers FTC254 -- http://www.brit-car....php?xProd=86477 or http://www.lrseries....Search+the+shop & RTC5841 -- http://www.brit-car....php?xProd=94418or http://www.lrseries....AFT-SPACER.html hth. do you still have the original spacer, if yes it would be worth refitting it. Quote Link to comment Share on other sites More sharing options...
mikec Posted June 11, 2012 Author Share Posted June 11, 2012 Yeah I think I still have it, it was that long between stripping and refitting I'd forgot it! Still can't decide what it does, all I can think is it stops the inner half shaft going to far into the cv cheers mike Quote Link to comment Share on other sites More sharing options...
western Posted June 11, 2012 Share Posted June 11, 2012 reckon your right, if the inner shaft went in to the CV to far it would most likely lock up & break. Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted June 12, 2012 Share Posted June 12, 2012 reckon your right, if the inner shaft went in to the CV to far it would most likely lock up & break. That is exactly what it's for, potentially the shaft could move far enough in to the cv joint that on full lock it could jam up and break. Regards, Steve Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 13, 2012 Share Posted June 13, 2012 When I did my front axle last, I forgot one put the whole side back together before saw it sat on the wing waiting patiently for me to fit it. Taking the CV off the shaft then broke the last clip I had and that happened at 4pm on a saturday, with nowhere to buy the clip! I hope I don't forget it another time Quote Link to comment Share on other sites More sharing options...
mikec Posted June 13, 2012 Author Share Posted June 13, 2012 When I did my front axle last, I forgot one put the whole side back together before saw it sat on the wing waiting patiently for me to fit it. Taking the CV off the shaft then broke the last clip I had and that happened at 4pm on a saturday, with nowhere to buy the clip! I hope I don't forget it another time Yep that's what I did, and also what I hope doesn't happen! Think I'll order a clip cheers Quote Link to comment Share on other sites More sharing options...
mikec Posted June 14, 2012 Author Share Posted June 14, 2012 Stripped it down tonight couldn't get the cv off the shaft the circlip wasn't perfectly round when I put it on (s*%#part) so ended up knocking seven bells out of it and now bust the cv so have to get another now Quote Link to comment Share on other sites More sharing options...
western Posted June 14, 2012 Share Posted June 14, 2012 oh dear, more expense. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 14, 2012 Share Posted June 14, 2012 Stripped it down tonight couldn't get the cv off the shaft the circlip wasn't perfectly round when I put it on (s*%#part) so ended up knocking seven bells out of it and now bust the cv so have to get another now Were you using a soft face copper or hide mallet? Mine took an absolute beating to get off but the CVs were undamaged. Quote Link to comment Share on other sites More sharing options...
mikec Posted June 14, 2012 Author Share Posted June 14, 2012 Were you using a soft face copper or hide mallet? Mine took an absolute beating to get off but the CVs were undamaged. Nope tried a block of wood to start with then gave up and used just the hammer. Looking at it after the circlip has broke in half, half in the groove and have in the cv Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 14, 2012 Share Posted June 14, 2012 That would be your problem then I guess you've shattered the CV with the hammer? Quote Link to comment Share on other sites More sharing options...
mikec Posted June 15, 2012 Author Share Posted June 15, 2012 Well I cracked the cage yeah. Lesson learned! Got a new cv and clip today but the clip is still not completely round. The original one was round, wish I'd left that on now Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 16, 2012 Share Posted June 16, 2012 Not sure what you are meaning by not round... It needs to sit out of the groove at rest to stop the CV moving. Post up a piccy Quote Link to comment Share on other sites More sharing options...
mikec Posted June 19, 2012 Author Share Posted June 19, 2012 Not sure what you are meaning by not round... It needs to sit out of the groove at rest to stop the CV moving. Post up a piccy Yeah but the old one was perfectly round but both new ones have a kink in either "end about 5mm from the ends. I think it's just down to the replacement part being not aswell toleranced perhaps than the original one. Unfortunately no pic as its on now, I'll try and get a pic tho Quote Link to comment Share on other sites More sharing options...
mikec Posted June 19, 2012 Author Share Posted June 19, 2012 Just done a google and all the pics of Rtc4820 are like my old one. But both my kits had the same odd clip one was britpart the other allmakes. Quote Link to comment Share on other sites More sharing options...
mikec Posted June 19, 2012 Author Share Posted June 19, 2012 Got a pic of half of my broken one, just found it on the road! Anyway I can't seem to post a pic on here cos I'm on iPhone. Pm me ur email and I'll send you the pic cheers mike Quote Link to comment Share on other sites More sharing options...
western Posted June 19, 2012 Share Posted June 19, 2012 it's a 'snap' ring designed to pass through out of the CV inner section & pulling through to the diff. item 5 page 416 here http://www.retroanac...ng_p398-471.pdf New part number http://www.brit-car....php?xProd=94244 pic below is a front inner shaft I busted a few years ago, it still has the bronze collar & snap ring fitted thought it might help, Quote Link to comment Share on other sites More sharing options...
mikec Posted June 19, 2012 Author Share Posted June 19, 2012 I know mate, but the thing is these ones I've got arent perfectly round so it either makes it harder to get off or breaks. If I figure out how to post a pic I'll put it up Quote Link to comment Share on other sites More sharing options...
mikec Posted June 19, 2012 Author Share Posted June 19, 2012 Quote Link to comment Share on other sites More sharing options...
mikec Posted June 19, 2012 Author Share Posted June 19, 2012 Above is what the original looked like This is the half that came with my aftermarket cvs. You can just tell on the left the way the radius tightens its more obvious when it's a full clip Quote Link to comment Share on other sites More sharing options...
western Posted June 19, 2012 Share Posted June 19, 2012 just extracted this from the shaft in my pic above, happy to post it to you. I prised one end of the snap ring to the shaft end with a thin blade then rotated the shaft while holding the raised end to stop it jumping back into the groove. Quote Link to comment Share on other sites More sharing options...
mikec Posted June 20, 2012 Author Share Posted June 20, 2012 Nice one mate cheers I'll send you details Quote Link to comment Share on other sites More sharing options...
