dicsosfa Posted July 5, 2012 Share Posted July 5, 2012 hi will a injector pump from a 200/300tdi disco fit a 200tdi defender as a mates is giving up the ghost and he does not have the internet at the moment to search for himself,, if so is it a straight swap or will it have to be adapted thanks Roy Quote Link to comment Share on other sites More sharing options...
Boydie Posted July 6, 2012 Share Posted July 6, 2012 The engine capacities are the same but I believe that the injection timing is slightly different, as I recall the 300TDi FIP. injects at around 5 degrees BTDC while the 200TDI is around 10 degrees, I'd guess that being the case that the simple answer would be no but that said there is no reason why it wont work if you're prepared to adjust the injection quantities and the timing, even if the timing is left as is it should run okay. Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 6, 2012 Share Posted July 6, 2012 I'm sure there have been topics on this before on here, can;t find pages as of yet, but see below: http://www.lro.com/forum3/viewtopic.php?f=19&t=26614 Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted July 6, 2012 Share Posted July 6, 2012 http://www.lro.com/forum3/viewtopic.php?f=18&t=81952 Quote Link to comment Share on other sites More sharing options...
Joe 90 Posted July 8, 2012 Share Posted July 8, 2012 have fitted a 300tdi to a 200tdi worked ok for me Quote Link to comment Share on other sites More sharing options...
