300tdi Brakes Not Very Good
AdeParko
Hi,
My brakes had started to feel useless, to the point where you were pressing the brake pedal right to floor just to get a bit braking going on
I needed stripped everything down to find the one rear caliper partly seized and the other not moving, so replaced both the rear calipers with new
Whilst there, I replaced all the wheel bearings, and also fitted new discs and pads all round
Bled the brakes using my ezi-bleed kit, and was a breeze as usual using this
Only thing I noticed is that when I connected the ezi-bleed to the master cylinder there is a hiss coming from the brake servo/master sylinder area?
Took the car out for a test drive; drives better and stops a bit better, but still not what you would expect.
Is there something else wrong? Anyone had any similar problems?
I'm thinking it may be servo or master sylinder related :(
Thanks
Adwe
As mmgemini has already said sounds like a leak in or around the servo have you checked the hose from the servo to the engine
I have a problem on the Disco1 300TDi I have just bought but on mine the brake pedal is rock hard like having a brick for a brake pedal on mine the vacuum pump is shot & I'm waiting for a second hand pump to arrive to hopefully cure my problem
Jim Day
I think the hiss may be a symptom - you could do with trying to find where it is coming from as it suggest a vacuum leak (can vacuum leak?), maybe pointing to a new servo needed. If you do need one, get a new non return valve as well (cheap, but they don't come with the servo). It's easy to swap the servo, and you don't lose any fluid. I'd imagine it stops basically Ok but the pedal feels very hard and 'dead'
I noticed a simlar thing on my 90. I struggled to work out what it was until I changed the rear axles (to upgrade fro mdrun to disk brakes). When I looked at the old flexible brake pipe I found it had gone soft near one end and, I guess, was expanding under pressure.
Ok, I realise I had changed the whole axle but the drum brakes never used to be that bad and when bending the old flexible pipe in various places you could see it was in poor condition near one end fitting.
Regards
MW
I dont think its a bleeding problem, I've never encountered any problems since using the Ezee Bleed Kit
I'm also starting to think master cylinder, I might try overhauling that to see if theres any difference, as thats probaly also the cheaper option as well
The way the Ezee Bleed works, by pressuring the top of the reservoir pot with air, if the master cylinder is faulty, could this causing the hissing noise?
I have had this problem with Ezibleed on a clutch circuit.
The hissing noise i obviously air escaping , but i would have thought if it was escaping thought the master cylinder in to the servo it would have signs of fluid loss.
I still would try bleeding again before stripping things apart.
On Defenders the servo tends to crack close to the four bolts that hold the master cylinder. Bogmonster has changed many down in the Falklands. I have only seen one with a crack and that was in a relatively new D110. I reckon the Disco will have the same problem.
  • 3 weeks later...
I've not really got any further with this as yet
I was however reading the Haynes manual and tried to follow the test sequence detailed in there
With the engine not running, I pumped the brake pedal and after a few presses the pedal was hard, no movement
I then kept my foot on the pedal whilst starting the engine. The pedal then dropped slowly all the way to the floor
From reading the haynes it should of dropped but only slightly before holding. Mine didn't do this, so does this indicate a fault? And what to?
Thanks
Ade
I wouldn't expect the brakes to be great on the first test drive - the pads and discs need to be bedded in by several hard applications to remove the protective coatings. The hiss from the MC could just be a small leak in the cap from the Ezibleed.
