schneide Posted October 22, 2012 Share Posted October 22, 2012 Hello Lr4x4 I bought a set of Volvo C303 portal axles to my defender. I've seen some driving around with these portals, but I can not find any pictures of the building. Does anyone have photos of their project? pictures of fittings and mountings? The idea is to be made a disc brake kit, and my 15'' land rover wheels must be fitted. Rasmus Schneidereit With Viking winch and soon Volvo C303 portals. 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 23, 2012 Share Posted October 23, 2012 You mean like this? I have the Portal-tek (now out of business) conversion, I don't think you can easily fit 15" wheels and even 16" can be a bit of a squeeze unless you do nasty things with spacers. Unfortunately I'm driving a Series so my spring mounts look like this: Which doesn't really help. There are quite a few conversions out there, some are really bad though. I don't have any pictures to hand but might have a dig on my home PC if I remember. If you need any spares drop me a PM, I have all the seals/bearings etc. Quote Link to comment Share on other sites More sharing options...
schneide Posted October 23, 2012 Author Share Posted October 23, 2012 Hello FridgeFreezer Thanks for your reply on Volvo C303. If you find some pictures of the shock absorber brackets and how others have mounted: Radius arm front and rear. and the spring brackets Rasmus Schneidereit DK Quote Link to comment Share on other sites More sharing options...
HoSS Posted October 23, 2012 Share Posted October 23, 2012 I've been in contact with a chap called David in Hampshire, who has a very interesting conversion kit. It uses LR calipers, modified LR discs and takes LR wheels. Which i will be buying as soon as funds become available. PM me for his contact details. Quote Link to comment Share on other sites More sharing options...
schneide Posted October 24, 2012 Author Share Posted October 24, 2012 tonight was me and two friends on Funen and get my C303 axles home. they look super good, and very compact. it must definitely going to be really good and get started. I would first find out what condition they are in. get seen on the bearings and seals. then will I make brackets to link the system. and when all this is over I'm going to and make a disc brake kit ... Here is the first real photo of the portals, they are just loaded on my companion's multifueler Quote Link to comment Share on other sites More sharing options...
HoSS Posted October 25, 2012 Share Posted October 25, 2012 @ schneide - there was no picture posted... @ fridge I've just developed oil seepage from one of my lower kingpins. I've never had the portals apart yet, and have a set of your bearing conversions to fit. 1. Does HOFS have any fitting instructions? 2. which seal is needed to fix my leak? and can you supply? also could be interested in the Stefa hub seal conversion x4 if you still have them. p.s. any news on the upper kingpin kit, did that ever get off the drawing board? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 26, 2012 Share Posted October 26, 2012 @Hoss - the lower kingpins don't have any oil in them, is it coming from higher up (CV boot) or something like that? Still got STEFA conversions, no problem there, just PM me. Upper kingpins still on the drawing board, not forgotten, just that they last that much longer than the bottom ones. Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted October 26, 2012 Share Posted October 26, 2012 Here is the picture he meant to post: Quote Link to comment Share on other sites More sharing options...
calle-fas Posted November 10, 2012 Share Posted November 10, 2012 Found this today. It's a company in northern Sweden that sells a conversion. 6 bolt conversion, but get in touch with them and see. 4-FUN Offroad Quote Link to comment Share on other sites More sharing options...
HoSS Posted November 11, 2012 Share Posted November 11, 2012 Thanks for the link Calle, although the site looks like its had all of 30 mins in its making, and no pics of the conversion. Nissan 6 bolt hmmm I still think the best i've seen is the one i mentioned from the UK. Uses LR discs and calipers, gives you LR 5 bolt wheels. Cheapest conversion of all i've found, and cheap & easy to find parts. Quote Link to comment Share on other sites More sharing options...
calle-fas Posted November 11, 2012 Share Posted November 11, 2012 Thanks for the link Calle, although the site looks like its had all of 30 mins in its making, and no pics of the conversion. Nissan 6 bolt hmmm I still think the best i've seen is the one i mentioned from the UK. Uses LR discs and calipers, gives you LR 5 bolt wheels. Cheapest conversion of all i've found, and cheap & easy to find parts. I agree with all above. I didn't find it particulary cheap either. Just wanted to highlight all options. If you ask me I don't think they actually do the conversion themselves. It is a brand new site and my guess is they probably sell some other companys solution. I'm not in any way involved with the site, just found it on a Swedish forum the other day. Quote Link to comment Share on other sites More sharing options...
HoSS Posted November 15, 2012 Share Posted November 15, 2012 ... or they will make the first prototype when someone orders one Quote Link to comment Share on other sites More sharing options...
calle-fas Posted November 16, 2012 Share Posted November 16, 2012 ... or they will make the first prototype when someone orders one Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted November 20, 2012 Share Posted November 20, 2012 Well he decided on doing a disc conversion himself, this is how it looks so far using LR caliper and discs: Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted November 20, 2012 Share Posted November 20, 2012 I hope he likes adjusting wheel bearings! The wheel mounting surface is a long way from the bearings center line. Quote Link to comment Share on other sites More sharing options...
94Discovery Posted January 6, 2013 Share Posted January 6, 2013 Well he decided on doing a disc conversion himself, this is how it looks so far using LR caliper and discs:[img=http://forums.lr4x4.com/public/style_images/master/attachicon.gif] WP_000489.jpg [img=http://forums.lr4x4.com/public/style_images/master/attachicon.gif] WP_000493.jpg [img=http://forums.lr4x4.com/public/style_images/master/attachicon.gif] WP_000494.jpg Any new updates? Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted January 7, 2013 Share Posted January 7, 2013 Yes plenty, but I cannot upload pictures sadly, so it'll have to wait till it's fixed Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted January 12, 2013 Share Posted January 12, 2013 As requested, some updates. Disc conversion done, Volvo hub lathed down and new hub made that sandwiches a defender disc, using the PCD of the disc, but with double the amount of holes (as this now holds the wheels on essentially) Anywho, a couple of pics: Quote Link to comment Share on other sites More sharing options...
94Discovery Posted January 13, 2013 Share Posted January 13, 2013 As requested, some updates.Disc conversion done, Volvo hub lathed down and new hub made that sandwiches a defender disc, using the PCD of the disc, but with double the amount of holes (as this now holds the wheels on essentially) Anywho, a couple of pics: [img=http://forums.lr4x4.com/public/style_images/master/attachicon.gif] WP_000650.jpg [img=http://forums.lr4x4.com/public/style_images/master/attachicon.gif] WP_000688.jpg Nice it is good to know a good machinist .Now lets see the rest of the built (i am using D2 radius arms on my Disco1 but i am early in mu build) Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted January 13, 2013 Share Posted January 13, 2013 Yeah well rasmus the owner (schneide) on here. Is a machinist himself, so no biggie for him. Well there isn't much else to the build as these are going under his 90" and will fit any coiler, but we will post a pic when they are fitted clearly Quote Link to comment Share on other sites More sharing options...
schneide Posted January 14, 2013 Author Share Posted January 14, 2013 The only thing I need to do with this project is to install new caster correct busches for the radius arms, and make new steel rims because it is 2100 mm width now with my time fitted 39,5-14,5-16 irok tires And maybe find a electric vaccum pump for the lockers ? Any idea there I can find a electric caccum pump on the internet ? Regards Rasmus Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 15, 2013 Share Posted January 15, 2013 With all of these conversions I'm very curious about the amount of material (thickness) left when you machine down the Volvo hub. Quote Link to comment Share on other sites More sharing options...
schneide Posted January 15, 2013 Author Share Posted January 15, 2013 Hello, I have not take material from the Volvo hub only from the diameter of the hub. Regards rasmus Quote Link to comment Share on other sites More sharing options...
seriebil.dk Posted January 25, 2013 Share Posted January 25, 2013 Nice Project schneide, looking forward to see it live this spring Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted January 27, 2013 Share Posted January 27, 2013 Axles were fitted yesterday: Quote Link to comment Share on other sites More sharing options...
