Hybrid_From_Hell Posted November 9, 2012 Share Posted November 9, 2012 Erm I'd put it inside, you'll have enough screened lead Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 9, 2012 Author Share Posted November 9, 2012 Loving the write up Mr Noisey, nice to have a good meaty thread to get my teeth into Cheers buddy, 'with a little help from my friends' and all that... Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 9, 2012 Author Share Posted November 9, 2012 Erm I'd put it inside, you'll have enough screened lead Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 9, 2012 Author Share Posted November 9, 2012 Ahhhhh! So what are we saying here?! I'd rather put it inside as originally planned but I now learn it has to be fitted to metal to heatsink it. I'd much rather it in the waterproof box but if that's a definite no then everyone seems to say engine bay to keep the coil wires away. What to do?! Just messing about so far tonight, no work done! Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 9, 2012 Author Share Posted November 9, 2012 Does it want to be in the box or mounted to a panel? Suppose best of both worlds is inside mounted to a panel?! Quote Link to comment Share on other sites More sharing options...
andy2986 Posted November 9, 2012 Share Posted November 9, 2012 On mine, I put the edis in the engine bay, bolted to the side of the inner wing near the brake servo. A bit of electrolytic grease on the connector.. Worked a treat!! HTH Andy Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 9, 2012 Author Share Posted November 9, 2012 Hmmmmm! Here's an option but It means running with the rest of the loom: Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 9, 2012 Author Share Posted November 9, 2012 I mean, if it's waterproof it's waterproof? Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 9, 2012 Author Share Posted November 9, 2012 What's the most important? Not running the coil wires with the loom. Not having the EDIS in the engine bay. Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 9, 2012 Author Share Posted November 9, 2012 It's going in the b*stard engine bay! Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 9, 2012 Author Share Posted November 9, 2012 Just opened it up, it's filled with jelly. Its waterproof! Quote Link to comment Share on other sites More sharing options...
mikec Posted November 9, 2012 Share Posted November 9, 2012 This took about two hours! Cheers! As someone who knows not much about ms installs I'd like to ask what that leads for? Presumably from the ms ecu to something? Quote Link to comment Share on other sites More sharing options...
mikec Posted November 9, 2012 Share Posted November 9, 2012 Also how much was that y piece from macc? Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 9, 2012 Author Share Posted November 9, 2012 It connects the ECU to the fuse/relay board Complete exhaust was £300 in mild steel, manifolds back Quote Link to comment Share on other sites More sharing options...
mikec Posted November 9, 2012 Share Posted November 9, 2012 So did you use the disco twin manifolds? Just wondering what the downpipes were like? I went in there a while back for some studs but they didn't have any, seemed a good setup there though. So back to the ms, that's the ms relay board or the vehicle one? I'm thinking of doing ms but struggling to get my head round it as I've never actually seen a kit yet Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 9, 2012 Author Share Posted November 9, 2012 No mate I've got hedman headers fitted, 4-1. Disco twin downpipes are just ok if you match the entries and port the manifolds, but they're limited to 3.5 really. It's an MS relay board mate, basically handles all your in/outs with screw terminals. So you make up a loom to link the ECU to the FR board, then all your loom connects to the board, and it's all ready fused and relayed. Makes the job simpler. Tbh i was the same, no ****ing idea until I started building, did some reading, then started to understand! Quote Link to comment Share on other sites More sharing options...
mikec Posted November 9, 2012 Share Posted November 9, 2012 I've just realised your only in alty, think I'll have to bob down for a nosey sometime if that's ok with you I'm only a few miles away. Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 9, 2012 Author Share Posted November 9, 2012 Yep no worries pal just let me know, Saturday afternoons are best Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 10, 2012 Author Share Posted November 10, 2012 Well, after a slow start to the evening, the decision was taken and the EDIS 8 was mounted on the inner wing. What swung it for me was the fact that I had a peek inside and everything was completely sunk in jelly. This unit is waterproof!! I was keen to heat sink it after learning it was a requirement (I kinda sussed that it had a metal back for a reason anyway) and I was keen to not run the coil control wires with the rest of the loom. This way they only meet 3" of the rest of the loom. EDIS was wired up, BIG earth to the battery (2mm) and an equal size supply to the relay board, and screened cable for the VR and SAW/PIP, with both shields soldered to pin 7. Then got on with fitting the coil packs that my brother very kindly cleaned up, and then fitted the first of the plugs, to the coils. Riding on the crest of this wave we did the CTS, PWM and MAT plugs. Will do the VR sensor tomorrow and the injector plugs (bit more tricky!) and hope to god that my plenum gasket arrives in the post. NB, I will be soldering the terminals into the cable for the VR sensor but will not fit them into the plug until it runs, which shouldn't be too long now!! Quote Link to comment Share on other sites More sharing options...
zardos Posted November 10, 2012 Share Posted November 10, 2012 I just wired up my VR plug as per the polarity diagram I found and it worked first time. Ref from http://www.autosportlabs.org/viewtopic.php?t=2373 Quote Link to comment Share on other sites More sharing options...
muttleyd Posted November 10, 2012 Share Posted November 10, 2012 Does your coil bracket reach the plenum cover? I had to fit the bracket on the back of the pump for it to all line up Looks like you are cracking on well. Still wading thro my install. Keep finding bits to improve on the wiring on the rest of the car at the same time. Do the Pip and Saw really need to be shielded? Has anyone run them without? Good luck with the rest of it. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 10, 2012 Share Posted November 10, 2012 Erm Sam The coil bracket goes on the rear of the timing cover and the thick washer makes up the gap and the the nuts etc Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted November 10, 2012 Author Share Posted November 10, 2012 Thanks for that info mate, best way to do it!! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 10, 2012 Share Posted November 10, 2012 http://www.megasquirt-v8.co.uk/3-5_etc.php See pic here N Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 10, 2012 Share Posted November 10, 2012 And as for the post office your shims and bungwent out 3 days ago 1st class recorded :0( Quote Link to comment Share on other sites More sharing options...
