Hybrid_From_Hell Posted November 25, 2012 Author Share Posted November 25, 2012 No Built up ECU 2 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 25, 2012 Share Posted November 25, 2012 Car is fully assembled? Car did run before? P.S: I've got some bits for you Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted November 25, 2012 Share Posted November 25, 2012 wrong fuel map? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 25, 2012 Author Share Posted November 25, 2012 Yes yes no 3 4 and 5 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 25, 2012 Share Posted November 25, 2012 So we've established it's got fuel and spark. Also fairly certain you said the coil is wired up correctly and this car used to run. So it has to be a timing issue of some description....... Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 25, 2012 Author Share Posted November 25, 2012 6 nope Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 25, 2012 Share Posted November 25, 2012 Mixture issue then? It can't be compression or it wouldn't have run before. You've already said it is getting fuel and has correct maps loaded so it musn't be getting air. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 25, 2012 Author Share Posted November 25, 2012 Nope 7 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 25, 2012 Share Posted November 25, 2012 Well I'm stumped then. It was running so compression and everything mechanical should be fine. It's getting the right amount of fuel (and of the right type) and the right amount of air. It's getting a spark and at the right time. It's spinning over at a good speed. It should at least go bloody bang! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 25, 2012 Author Share Posted November 25, 2012 So was I ! Keep going all, there was an answer Quote Link to comment Share on other sites More sharing options...
luke keeper of badger Posted November 25, 2012 Share Posted November 25, 2012 sticking injector/s flooded ? Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted November 25, 2012 Share Posted November 25, 2012 Did it fire at all or was there simply nothing? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 25, 2012 Author Share Posted November 25, 2012 No and no 8 9 Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted November 25, 2012 Share Posted November 25, 2012 was the engine turning over the correct direction? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 25, 2012 Author Share Posted November 25, 2012 Yup 10 Quote Link to comment Share on other sites More sharing options...
Quagmire Posted November 25, 2012 Share Posted November 25, 2012 It had fuel, but was it the right kind of fuel? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 25, 2012 Author Share Posted November 25, 2012 Yup 11 Quote Link to comment Share on other sites More sharing options...
Fatboy Posted November 25, 2012 Share Posted November 25, 2012 Had the person fitted the fuses into the relay board? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 25, 2012 Share Posted November 25, 2012 It had fuel, but was it the right kind of fuel? Yup 11 That question had already been asked so shouldn't count Did it have diesel in the tank? ( if not it should have ;-). ) Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted November 25, 2012 Share Posted November 25, 2012 So it's got a spark, the leads are correct, it's pumping in fuel. Must be air... Something to do with the throttle? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 25, 2012 Share Posted November 25, 2012 So it's got a spark, the leads are correct, it's pumping in fuel. Must be air... Something to do with the throttle? think that has been covered to Mixture issue then? It can't be compression or it wouldn't have run before. You've already said it is getting fuel and has correct maps loaded so it musn't be getting air. Nope 7 Quote Link to comment Share on other sites More sharing options...
duncmc Posted November 25, 2012 Share Posted November 25, 2012 Is the firing order correct, plug leads in the right order at both ends? Are the injectors plugged in to the correct leads, again are they in squirting in the right order and not mixed up? Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted November 25, 2012 Share Posted November 25, 2012 think that has been covered to I was edging towards too much air - like throttle jammed open rather than not getting any. Quote Link to comment Share on other sites More sharing options...
Quagmire Posted November 25, 2012 Share Posted November 25, 2012 Whoops- skim reading from my phone again Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 25, 2012 Author Share Posted November 25, 2012 No no no and no 15 Quote Link to comment Share on other sites More sharing options...
