Mounting suggestions LED light bar
Before putting too much thought into it I went ahead and got a 41.5" LED light bar trough the group buy.
I don't really know where and how to mount it. Was thinking in the grille first but the roof is probably better considering the size of it.
I don't have a roof rack so I will probably need aroof bar.
I would be driving " through" trees often enough so I need the bar a bit protected or at least round corners for branches not to catch.
How have other people been mounting there?
Do these lights have much screen glare when on a bar? With normal roof lights ideally you want them set back up the roof a little to stop glare on the windscreen and bonnet a certain amount.
Will
Will
we fitted a 22" light bar above the screen on the buggy for the wooldrige trophy, very little glare through the screen, if you want i can post some in car video at night of the testing we did?
If you are interested in a roof bar, these guys:
http://www.roc-ard.co.uk/index.php/shop/category/view/1
Are currently building me one with custom fittings for the same sized light bar - its been fabbed and is currently at the powder coaters, should be with me at the end of next week. When it turns up I'll post pics and a review etc, I think the plan is that once they've confirmed mine's OK, they will be set up to make others as a standard item..
Cheers
Jon
To be fair I'm only jealous after fitting 4 spots on my disco milkfloat right above the screen and being dazzeled as hell!
I think one of those bars would be worth more than my heap.
Will.
Cheers
Jon
Keep us posted on this one as I'd definitely be interested!
Does it come with mounting for CB?
