mickeyw
Re-flooring my trailer
36 posts in this topic
Hi all, hope this isn't too O/T...
I'm replacing the floor on my ancient Ifor Williams flat bed trailer.
What's on there is 3/4" ply and was perfectly strong enough to carry a Landy before it rotted out.
I've bought new WPB ply, but I'm wondering what to preserve it with. The old floor had a water based shed n fence paint on it but it didn't last long with all the wear and abrasion a trailer floor sees.
Can anyone suggest a product that won't attack the glue in the ply?
I was considering Sikkens Cetol plus, as my shed was coated with that 10 years ago and still looks good, just not sure about solvents.
I also wondered about decking preservative, as that I'd think that would take a fair bit of wear.
Your thoughts please gents?
Share this post
Link to post
i just replaced the floor on my Indespension beaver tail, i used the proper trailer flooring with the grippy surface on the top side, once it was down on the chassis i went round all the edges & sealed it to the frame with a big bead of silicone that i spread/ pushed into the gaps on the cut edges
Share this post
Link to post
Yes I know the stuff, and not sure where to get any though.
What sort of £ per sheet BTW?
Share this post
Link to post
The phenolic stuff we used to use is branded as Wisadeck.
I prefer keroin planks. Stronger, longer lasting and easy to replace small sections. Naturally none slip.
Share this post
Link to post
Hmmmm, so I looked up Wisadeck, and for 18mm sheet it costs a mere £100 inc VAT + carriage, give or take. So for my 12' trailer that would be a whopping £300!!! I like the fact that it has a non slip surface, but not at that premium!
The Buffalo board comes in marginally cheaper, but by the time VAT and carriage is added we're back near £300.
When the same thickness WPB ply costs £25/sheet and the merchants is 1 mile from home I can replace it a few times before I have bought Wisadeck.
The ply boards that are on there currently have lasted at least 10 years, so they have done well really. Will I still have this trailer in 30 years time, who knows? Some law will probably have been passed to make its use illegal before then anyway, :lol:
Even by the time I have bought some preservative I won't have spent much more than £100 on materials.
I shall still have to cut and fit the new boards whatever the material, so no savings to be had there.
Oh and did I mention I have already bought the ply? ;) So still looking for the right preservative.
Thanks for the suggestions though gents.
i later found mesh faced plywood at £32/sheet + VAT & carriage, coming in at £160 delivered, doesn't sounds quite so bad and may have been a viable alternative
Share this post
Link to post
i had to put a new floor on a 14ft indespension beaver tail back in june, the fella said he wanted 6x2
treated timber put on it so we did and i seen it a few weeks ago in person and it has held up extremly
well just a bit dirty considering at has been carrying scrap metal, scrap cars and probably alot more.
how long it does last is another question.
Share this post
Link to post
A large tin of roofing liquid rubber is about £30 from B&Q, that is enough for 3 layers on ply. Its intended for flat roof repair so it sticks really well and acts as a non slip surface. If you treat the underside before putting on the trailer you will have a completely sealed panel that will last years. If you screw shallow sacrificial runners either across or along the length of the panel, it will make the surface last even better.
Eric
Share this post
Link to post
Eric, that sounds a good idea, thanks.
I notice that on the sites selling Buffalo board and similar, they talk about resealing the edges if you cut the sheets. Suggested sealing material is an acrylic paint.
Share this post
Link to post
I got phenolic ply board from arnold lavers a couple of years ago for mine, £40 a sheet so £160 for the whole trailer. The old stuff had gone as the person who put it on hadn't sealed the edges they'd just put a bit of silicone on so I used decking edge sealer after I'd cut to size. It is thin and really sinks in.
Not much use if you've bought your timber already? Have you thought of creosote it soaks in to timber pretty well.
Share this post
Link to post
Would adding sand to the liquid rubber mentioned above improve both it's grip and wear resistance?
Share this post
Link to post
The glues in plywood do not like creosote at all - don't ask me how I know :lol:
Share this post
Link to post
CW, adding a sprinkle of sand would improve grip but sand tends to encourage slime growth. Using some kind of roofing grit would have the effect without the risk of eventual slipperiness.
I intend coating the inner panels of my 110 front doors when I eventually replace them. Cant fault it for waterproofing and air tightness. You can use it to line pools tooo so its pretty useful stuff and non toxic when set.
Eric
Share this post
Link to post
Thats the kind of thing I mean. I think they use something like it for antislip surfaces on grp boats.
Eric
Share this post
Link to post
My trailer floors gona need done soon too but i will be using chequer plate instead of ply as it will last alot lot longer.
Share this post
Link to post
Each to his own I guess. I find chequer cold and slippery. I use my trailer and will use my renovated 110 for camping and metal detecting trips, and use the large internal space as a tent. Wood and rubber are far more comfortable to sleep in and warmer than bare metal. Condensation isnt so much of a problem and padding around in socks or bare feet is not too uncomfortable either.
If your using the floor for carrying loads and messy stuff this wouldnt be a consideration.
Eric
Share this post
Link to post
I painted the bench in my new garage with a grippy decking varnish stuff - seems hard wearing on a bench!
Share this post
Link to post
Probably a bit late now, but my local supplier can get 12mm wisadeck for £23 a sheet. I just bought 2 sheets to ply line the floor of my transporter.
Supplier name is Alpha Timber Solutions just outside Milton Keynes
Share this post
Link to post
Gents,
Thanks for all the suggestions.
Eric I am with you on the chequer plate, too slippery, also it woulld need more support than I have due to its relative lack of thickness.
The grit in the varnish idea has been noted, as has the deck varnish.
I would hope any flooring varnish ought to be pretty hard wearing. In fact I remember than I painted my bedroom floor boards with some Ronseal 'diamond hard' or similar varnish. Could also be worth a go.
Share this post
Link to post
Old thread I know, was wondering how you got on with this Mickey?
My trailer needs a new floor and I'm looking at the options available. It also needs new wheels, tyres and lights so there's gonna be some expense whatever happens!
Share this post
Link to post
Be aware that there is resin coated ply on the market purportedly for trailer flooring that is actually really low grade softwood with the minimum amount of resin coating and NO rot proofing at all internally .
.........Can you tell I got royally ripped off about 5 yrs ago when I re-boarded my 14' x6'6" flat bed - almost £400 lighter and the boarding is now like sponge .......the original boarding lasted around 20years of hard use and living outside all the time . I think I will be using 5mm Al checker plate this time .
Gwaza/Farmpower in Shrops. are good value for lights etc
cheers
Steve b
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
