power steering installation for ex-MOD Defender 90
jameshub
It was a few years back but I think I only paid about 45 quid, that was for box, pipes, pump, pump mount and reservoir. I sufferd without ps for a couple of years, once Id done it, it was one of those "why didn't I do this at the start" moments
presuming you have a 2.5n/a diesel engine, you need the following:
power steering box - ideally from a Defender with swan neck drop arm, otherwise you have to swap the drop arm (PITA) or modify steering drag link.
Power steering pump from n/a or TD defender
power steering reservoir
the bracket which holds the pump to the engine
pipework
a different crank pulley - needs two grooves, both same diameter
power steering belt
rough cost £100, takes a few hours to do.
pipework
power steering belt
yes i do have the 2.5n/a so this is great info, thanks
