dirtydiesel Posted April 30, 2014 Share Posted April 30, 2014 I converted my last set of unimog 404's to use Mercedes G wagon discs and calipers giving me a 5x130 stud pattern and the ability to fit 15" wheels. Getting 5x130 wheels was never easy, and now nearly every wheel I have is 6x139. So I'm making a fresh conversion to 6x139, I'm trying to push the wms as far back as possible as well. I'm still going to build to fit 15" wheels I'm just not sure on what calipers to use yet. I needed some 6 stud discs with a shallow bell, I've chosen apec dsk900 off a hilux ln105, 302mm diameter 20mm thick. First steps were turning all the standard wms off the unimog hub, I'm pretty sure the mog hubs are surface hardened as the outer few mm put up a fight and slowed me down a lot! 1 Quote Link to comment Share on other sites More sharing options...
zim Posted May 1, 2014 Share Posted May 1, 2014 I recognise that hub.... I've been tripping over it in my lockup for the last 18 months ! LOL Like the work Now come collect your next axle.... G Quote Link to comment Share on other sites More sharing options...
Lewis Posted May 1, 2014 Share Posted May 1, 2014 I have nothing constructive to add, but I really enjoy a good tech thread like this. I'm looking forward to see it progress 1 Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted May 1, 2014 Share Posted May 1, 2014 Finally someone doing something to Mog axles again! seemed like they had all suddenly disappeared from the face of the earth! Will be following with great interest seeing as I have the Mog/LR hybrid axles floating around, and the only thing they really need is a good disc conversion. Its just that pesky portal housing seems so big to wrap any wheel around that is less than 17".. But then again these days 17" aren't all that bad seeing as more and more 4x4 tyres are being made in this size. Quote Link to comment Share on other sites More sharing options...
discomikey Posted May 1, 2014 Share Posted May 1, 2014 mmmm shiny! Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted May 7, 2014 Author Share Posted May 7, 2014 A little more progress, I need to order some hilux wheel studs and then I should be ready to trial fit a wheel so I can squeeze a caliper in. Quote Link to comment Share on other sites More sharing options...
Lewis Posted May 8, 2014 Share Posted May 8, 2014 How did you mark out/drill the wheel stud holes? Do you have an dividing table or did you do it the old fashioned way with a scribe and lots of measuring? Quote Link to comment Share on other sites More sharing options...
elbekko Posted May 8, 2014 Share Posted May 8, 2014 Not sure how DD would do it, but I think I'd just sketch it up in Solidworks or something, print it off, cut out the holes and mark that way. Of course measure that it hasn't accidentally printed at 99% or something... Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted May 8, 2014 Author Share Posted May 8, 2014 Zeus book and a bit of patience. Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted May 8, 2014 Share Posted May 8, 2014 How did you mark out/drill the wheel stud holes? Do you have an dividing table or did you do it the old fashioned way with a scribe and lots of measuring? You just email the drawing off and the part arrives don't you? Quote Link to comment Share on other sites More sharing options...
Lewis Posted May 8, 2014 Share Posted May 8, 2014 Do you have any photos of your g wagon brake conversion? And description of how the new conversion will differ? Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted July 17, 2014 Author Share Posted July 17, 2014 Do you have any photos of your g wagon brake conversion? And description of how the new conversion will differ? I don't have any pictures of the g wagon disc conversion, when I get chance I'll dig a portal box out and take some pics. Other than the pcd change I have pulled the wms further in closer to the portal box I also want to integrate the caliper bracket into a portal box brace. I have made a little more progress, not much though! Quote Link to comment Share on other sites More sharing options...
Lewis Posted July 18, 2014 Share Posted July 18, 2014 I have made a little more progress, not much though! 'Bout time! Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 18, 2014 Share Posted July 18, 2014 Fascinating! Dumb questions: Taking that much off the hub doesn't weaken it, does it? It shouldn't as you put the strength where it's needed with the revised PCD wheel flange that you turned up. Is that last photo the outside of the hub, where the wheel seal land is? And the studs are fitted to the disk? And finally (sorry) did you mig the revised PCD flange to the turned down hub? I just love these threads, I learn so much! Thanks, Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted July 18, 2014 Author Share Posted July 18, 2014 'Bout time! I know, I know...... too many projects, too little time! Fascinating! Dumb questions: Taking that much off the hub doesn't weaken it, does it? It shouldn't as you put the strength where it's needed with the revised PCD wheel flange that you turned up. Is that last photo the outside of the hub, where the wheel seal land is? And the studs are fitted to the disk? And finally (sorry) did you mig the revised PCD flange to the turned down hub? I just love these threads, I learn so much! Thanks, No such thing as dumb questions! Turning all the excess unimog wheel flange won't weaken the hub at all, but undoubtedly welding the new flange on is not as strong as if the hub were all all machined out of one piece. Both pics are of the outside of the hub, the seal land is on the back of the hub. The wheel studs are ln105 hilux the same as the discs, they are a dead fit through the disc and a press fit into the hub. Yes I used mig, about 300 amps, 3 passes on the outside (root with 2 caps) all stop starts overlapped (i really need to make myself a positioner!), 1 pass on the inside most of which was turned away as the inner weld formed the tapered register for the disc. almost none of the outer weld was machined off. Pressed it all together and had a trial fit in my wheels. Managed to lose the portal box completely in the wheel, I should have 50mm of the outer swivel inside the tyre as well. :-) Quote Link to comment Share on other sites More sharing options...
Lewis Posted July 19, 2014 Share Posted July 19, 2014 What size is that wheel? & what's the offset like? Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted July 20, 2014 Author Share Posted July 20, 2014 What size is that wheel? & what's the offset like? 17x9, 7" back spaced. I have tried it in a 7j15 et25 wheel and there is plenty of space, I will mount the calipers to fit inside the 15"s so I can fit whichever tyres I want. Quote Link to comment Share on other sites More sharing options...
Daan Posted July 21, 2014 Share Posted July 21, 2014 Looking good, as always. Are you using a single caliper? the double caliper solution always looks a bit, well, not so factory. On which car is this going to live? I lost track of what is in the traffic jam in front of your garage. Daan Quote Link to comment Share on other sites More sharing options...
steve b Posted July 21, 2014 Share Posted July 21, 2014 Some quality machining and fab as always DD , it looks like being a well sorted conversion . the calipers and mounts are what I'm really interested to see . Daan , the bigger 'Mogs have twin calipers all round , the second pair on the rear being for the air HB cheers Steveb Quote Link to comment Share on other sites More sharing options...
tomcat404 Posted December 30, 2015 Share Posted December 30, 2015 Any more on the thread ? Quote Link to comment Share on other sites More sharing options...
Ercial300 Posted June 11, 2016 Share Posted June 11, 2016 Anymore updates on the thread? Quote Link to comment Share on other sites More sharing options...
Ercial300 Posted June 11, 2016 Share Posted June 11, 2016 Anymore on the thread? I'm interested to see how it's coming along Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted June 11, 2016 Share Posted June 11, 2016 last i heard, hes left the 4x4 scene and moved on to track cars? hence why im guessing he hasnt been to this site in 8 months. Quote Link to comment Share on other sites More sharing options...
Ercial300 Posted June 13, 2016 Share Posted June 13, 2016 Gutted I was hoping he was still making disc conversions Quote Link to comment Share on other sites More sharing options...
Keith McElroy Posted August 25, 2018 Share Posted August 25, 2018 On 7/17/2014 at 6:45 PM, dirtydiesel said: I don't have any pictures of the g wagon disc conversion, when I get chance I'll dig a portal box out and take some pics. Other than the pcd change I have pulled the wms further in closer to the portal box I also want to integrate the caliper bracket into a portal box brace. I have made a little more progress, not much though! Hello guys...I’m a Unimog owner and looking to do this very thing to convert to disc brakes and need help with details on the complete build in these pictures...if someone would please contact me and help guide me through how to build these that would be highly appreciated...I have looked everywhere and this seems to be a AWSOME forum to be a part of...THANKS IN ADVANCE Quote Link to comment Share on other sites More sharing options...
