Volvo C303 Overlander Build
For the cab tilt, why not use some coil springs near the front and keep it all mechanical? I'd never seen this arrangement until I recently got a Gaz 66 and it works really well.
Can you post a few more pics of your hinges and lock assembly? I've been meaning to make a tilting cab for years.
How does the steering column get on with the tilting cab?
  • 1 month later...
A bit of an overdue update. Have done the following stuff:
- Painted and fitted the upper cab
- Started on the rewiring
- Made new dash & switch panels
- Constructed a battery & compressor box
- Cab latch and support frame made
Pics below:
Cab top fitted
img_0178medium_zps64d2f3eb_22333381265_o.thumb.jpg.9c308fb3c49ce392dc7b1cb322ffa32e.jpg
A nice set of new wooden bump strips
img_0214medium_zps1f6aed5c_22320299662_o.thumb.jpg.4d4bf0d28989cb24a864f752185ac74e.jpg
  • 3 weeks later...
Amazing!
I'm currently planning out a very similar set-up for my 130 expedition vehicle, except using a mechanical injection pump on the engine.
May I ask where you bought the 722.6 controller, and how much you paid?
Will be subscribing and following this with much interest!
The documentation is here https://docs.google.com/document/d/1_WiBay-rg3oWv8VhuVyUuVJ-f22PwEzD5N_LuAQHUNI/edit
You need to email Ole Fejer his address is on the doc, price is around 400 Eur
  • 2 weeks later...
Looks great
I'd quite like to swap out the difflock vacuum controls, after 40 years they look a bit fragile.
How have you integrated switches on your dash to the diff locks?
Steve
I dont quite understand. Do you mean you also have a C303 that you want to swap the controls on? Or are you recommending that i do it?
I have replaced all of the vac piping and removed the orignial manual valves, replace those with a bank of 3 solenoid valves controlled by the switches.
  • 3 weeks later...
I have a c304 and wondered how you'd moved away from vacuum diff locks
Are you willing to PM me details on your solution
My set up is detailed here www.pearman.cc/blog
Steve
  • 2 weeks later...
