HoSS
Volvo C303 Overlander Build
157 posts in this topic
any more infoon the mods to get the engine running on factory management???
Yes sorry, I have been rather busy with my new job. I need to find time to write it all up.
Share this post
Link to post
Great Idea, i've been looking at the 303 to convert to a camper myself, I'd love to see how the enginge conversion works out.
I'll be watching with interest
Share this post
Link to post
Well i found out one reason why the fuel system wasnt running as well as it should have been.... I had the feed and return pipes swapped :blink:
Share this post
Link to post
Any news on switching off the immobiliser and installing the factory ECU? I'm running an e300 as a daily. What an engine!
Share this post
Link to post
A bit of a long overdue update. Recent progress:
- Installed marine cables for the transfer box high/low and the autobox selector.
- Moved the battery box and OBA compressor between the chassis.
-Transfer box tested in place, and crossmember constructed.
Some pics:
Crossmember
Battery and compressor boxes
Compressor box contents
The lifting cab in action
isolators & main fuses
The custom manifold
OBA tank
New version dash panel
Share this post
Link to post
The crossmember in place. I just need to add a bracket at the rear to support the transfer box.
Share this post
Link to post
I do wish the body just lifted like that on my 88 sometimes!
Yeah its a nice feature, glad i did it. Its even worse on a standard C303, you have do do all your maintenance through the wheel arches or through a hatch in the cabin only 50cm x 75cm. (Which also makes the cabin more noisy. Have welded that up)
1 person likes this
Share this post
Link to post
First of all: great project! I love these Volvo's! :-)
But also some (hopefully usefull) criticism:
- the crossmember looks like two leafsprings connected with a piece of box section: not very stable. :unsure:
- and the lock for the cabine, is that attached with only two vulcanized rubber mounts? What happens when these shear off? :wacko:
Share this post
Link to post
How's that going?
Its about 1/3 done, but unfortunately comes second priority to paid work.
Share this post
Link to post
Hi Hoss
Must be time for a detailed update. I'm getting withdrawal symptoms! Plus I need inspiration for my project putting an OM606 into a C304 6x6
Cheers
Nick
Share this post
Link to post
Sorry for the lack of updates, but not much has happened. Time is more scarce since starting a new job.
I've also rethought the plans for the rear camper body, so have actually move backwards and changed a few things.
- Got rid of the air/water intercooler, and will fit an air intercooler behind the cab.
- Still thinking on how to get more axle/engine clearance (move up = lift cab more, move back = a big PITA, dry sump, doesnt help much)
- Rear body will be a hard side lifting roof similar to the picture below. Am going to invest in a TiG to make up the Ali frame. Have to finish design and locate Alu profile. Source composite wall panels.
hi what make are the vacuum and oba gauges your using?
Keyence AP series, you can find them trade, or sometimes on ebay.
I must've missed it - why so much on-board air capacity on an overlander? :huh:
Didnt think i'd overrated it, with big tyres to fill, air tools perhaps. Anyway the compressor and tank were a freebie taken from a 90 equipped with trailer air braking.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
