Bingy Posted November 9, 2014 Share Posted November 9, 2014 Whilst im upto my ears still doing the devils knitting, would it be advantageous to fit an Air Fuel guage? I know that this can be monitered on the laptop, but i dont always want to drive around with that plugged in. Whilst im adding wires and electrickery i thought that this could be a viable guage to install. Thanks Quote Link to comment Share on other sites More sharing options...
bobtail84 Posted November 9, 2014 Share Posted November 9, 2014 Normally when you've set the AFR up on M.T or T.S that's all you need to do but if you want to just nose from time to time I would suggest using shadow dash. You can then monitor the AFR on your phone.. Quote Link to comment Share on other sites More sharing options...
Bingy Posted November 9, 2014 Author Share Posted November 9, 2014 Cheers. I'll have a look at it Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 9, 2014 Share Posted November 9, 2014 For AFR you normally need a wide band, and to do that, you will be replacing £50+ sensors every time you go wading, I wouldn't bother. Quote Link to comment Share on other sites More sharing options...
Bingy Posted November 10, 2014 Author Share Posted November 10, 2014 Thanks for that. I didn't even consider the sensor. Now I've got a 52mm hole in the dash I need to fill. Looks like I need to get a clock Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted November 10, 2014 Share Posted November 10, 2014 Fuel pressure gauge? I fitted one when I had an engine problem and it's turned out pretty handy. I just use an electronic oil pressure gauge. I think the fuel pressure should be 2.5bar above manifold pressure if I remember correctly. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 10, 2014 Share Posted November 10, 2014 For fuel I generally put a clear inline filter in the return line, that shows you if fuel is flowing and it's a short step from there to deciding if the pump is dead, PRV is stuck open or closed, etc. Quote Link to comment Share on other sites More sharing options...
