stuck Posted November 22, 2014 Share Posted November 22, 2014 Chaps, My 4.6 has decided it would prefer to be a 7 cylinder so one of the injectors has thrown it's hand in. Is it good practice to change all 8 & if so where should I be buying them from to ensure they don't come in blue boxes? Cheers, Mick. Quote Link to comment Share on other sites More sharing options...
kevindawes Posted November 22, 2014 Share Posted November 22, 2014 I was in the same boat as you a while back. What I did was send them all to a company I found on ebay who serviced them for £15 each. One of them turned out to be faulty and had been dumping twice as much fuel through as was required. They send you graphs showing the flow rates before and after the service. I just bought one new injector and knew then I had a fully functioning set, which basically meant I could confidently move on to thing that wasnt working properly Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 22, 2014 Share Posted November 22, 2014 Hotwire injectors are actuallu quite cheap new, turn rail upside down and crank, anything that squirts vs a misting is sticky I swear by FORTE injector cleaner, 2 x bottles in a little tank of fuel - less the better so stronger.. Often will clean them up if just gooed up with goo lol Or a good s/h one and then run FORTE through the lot 3.9 4.0 4.6 all the same units Nige Quote Link to comment Share on other sites More sharing options...
stuck Posted November 22, 2014 Author Share Posted November 22, 2014 Thanks both. Nige, I'll give you a call Monday if it's ok, want to order a set of new injector plugs. Quote Link to comment Share on other sites More sharing options...
stuck Posted November 25, 2014 Author Share Posted November 25, 2014 (edited) Anyone know if (assuming you change all 8) you can use the green Thor injectors in a GEMS engine with MS? The green ones are physically smaller but the fuel rail & engine side O-rings look to be the same. No you can't. Stupid boy. Edited November 25, 2014 by stuck Quote Link to comment Share on other sites More sharing options...
elbekko Posted November 25, 2014 Share Posted November 25, 2014 No, the injector rail doesn't reach down low enough. You could use the Bosch fuel rail, but then also have to find a way to add a return. There's a schrader valve on there (for checking pressure I think), that you can put a pipe over for the return. Quote Link to comment Share on other sites More sharing options...
bobtail84 Posted November 26, 2014 Share Posted November 26, 2014 You could use the Bosch fuel rail, but then also have to find a way to add a return. There's a schrader valve on there (for checking pressure I think), that you can put a pipe over for the return. If you take the valve out you can use is as a return as I have on the Thor conversion. Quote Link to comment Share on other sites More sharing options...
elbekko Posted November 27, 2014 Share Posted November 27, 2014 Yup, that's what I meant Quote Link to comment Share on other sites More sharing options...
stuck Posted November 30, 2014 Author Share Posted November 30, 2014 Cheers Chaps, Is there a reason you would fit a Thor inlet manifold to a GEMS engine? Quote Link to comment Share on other sites More sharing options...
elbekko Posted December 1, 2014 Share Posted December 1, 2014 To run Thor injectors, that's about it. I just remembered, if you don't fit the Thor lower intake, you'll have to do some grinding to clear the fuel rail. Or try to bend the pipes of the fuel rail, but I'm not sure that's such a good idea. Quote Link to comment Share on other sites More sharing options...
bobtail84 Posted December 1, 2014 Share Posted December 1, 2014 Cheers Chaps, Is there a reason you would fit a Thor inlet manifold to a GEMS engine? The reason the Thor engine came about was due to the punter whining that his/her Disco/RR with the Gems V8 wouldn't pull Tarquins/Ptracey's horse box, trailer, whatever with enough speed to keep up with the local milk float so Landrover came up with the Thor engine which is basically an inlet modification. It offered more torque at the bottom of the rev range to the detriment of top end BHP. This is OK in a Landrover pulling a trailer weighing enough to create it's own gravity but not for the go faster chaps.. That's what I heard anyway. Any road up have a look here Quote Link to comment Share on other sites More sharing options...
stuck Posted December 1, 2014 Author Share Posted December 1, 2014 Thanks for that. 1 Quote Link to comment Share on other sites More sharing options...
