custom fuel tank, MS, which external fuel pump?
dirtyninety
I use a pump from an old Jag, Bosch 4FP or something that will give you the right flow and pressure. Don't forget that the Rover Efi has a PRV on the fuel rail so as long as you have more pressure than you need the rest will feed back to the tank (as long as you remembered to run a return pipe..)
There are lots on eBlag or just pop down to your local breakers and get one out of the boot of an old Jag or Damian sovereign.
HTH
