PeteMck Posted March 4, 2015 Share Posted March 4, 2015 Hi Guys, Having trouble with my megasquirt. It's a rover 4.6v8 When I crank I get a spark, when I turn the ignition on it fires 2 priming pulses. However while cranking the fuel pump runs fine but the injectors stop opening, and so obviously it won't start. from this I'm ASSUMING that the wires for the injectors is correct, the edis module is wired in correctly as its making a spark and that the msq module is getting a signal from the edis 8 module as the fuel pump is running and I'm getting ab rpm of around 350. Any suggestions? I'm guessing one of my assumptions is wrong? Thanks in advance for any help Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted March 8, 2015 Share Posted March 8, 2015 I assume it used to run and now it doesnt? What's your throttle position showing? There's a flood clear setting where it doesn't injection t fuel under cranking if you floor it. Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted March 8, 2015 Share Posted March 8, 2015 Sorry, just read the other post Quote Link to comment Share on other sites More sharing options...
