Laptom Posted March 11, 2015 Share Posted March 11, 2015 I got the set of Nigel running for 3-4 years now. Working great and flawless, till now.... After a few months of no use, I wanted to started my offroader (86 RRC 3.5 EFI with 3.9 Inlet and full MS1 with EDIS set from Nige). Nothing... Engine is rotating, but not even a cough. - Check the spark first, all 8 no spark - Check the timing in Tunerstudio. All ok - Check rpm in Tunerstudio, At startup around 150rpm - Removed the EDIS to MS connection (should run on a fixed 10 degree) - Checked voltage at middlepoint of 2 coils (Ford). 0V when in rest, 12+V when ignition is on, 11V when starting - Changed complete EDIS module with a known working one. Still no spark. EDIS just needs the timing from the trigger wheel (is working because got rpm in Tunerstudio and polarization is ok (run with it for more then 3yr without issues) EDIS changed with known good one. Coils get power. What more can I do? Thanks, Tom Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 11, 2015 Share Posted March 11, 2015 Two dead coil packs sound pretty unlikely, but I suppose it is possible? Checked all your earth points? When checking for spark are you just removing one lead at a time? Aside from that I think you have covered all bases. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 12, 2015 Share Posted March 12, 2015 Hmmm Odd !Suspect VR sensor, or connection at VR sensor, super clean pins etc and see ? Is the Fuel pump still priming and shutting off when ignition on ? guessing it is ? Other than the above check the earths are clean and decent...earths can cause all sorts of weird results if wrong !Report back Nige Quote Link to comment Share on other sites More sharing options...
Laptom Posted March 12, 2015 Author Share Posted March 12, 2015 Thanks guys! I checked the battery and even tried the Red Top from my daily diesel RRC. Fuel pump is priming for a couple of seconds (also my second pump in the second tank). Also LPG will be released when actually starting. I haven't checked the coil packs; 2 Broken sounded pretty strange to me. I have a new one somewhere, a good point to try and you never know. One thing I just started to remember, the MS+EDIS Rover never missed a beat in 3 years, until the last night trip a couple of months ago. The car sputtered a couple of times, but it kept going and the last 3 hours of the trip without sputtering or issues. The night trip was really wet, muddy and fun. I just thought the VR sensor got a bit dirty. Nige, I will mail you for a new VR sensor and a possible spare one. It is good to try it. Otherwise I don't know. Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 12, 2015 Share Posted March 12, 2015 How does the trigger wheel look? Not too rusty? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 13, 2015 Share Posted March 13, 2015 Sounds like you got a rusty connector somewhere.... Quote Link to comment Share on other sites More sharing options...
Laptom Posted March 16, 2015 Author Share Posted March 16, 2015 I'll check wednesday evening. Should be an easy solution. Still would be easy to have a spare VR sensor. Quote Link to comment Share on other sites More sharing options...
Chazza Posted March 17, 2015 Share Posted March 17, 2015 I had similar symptoms on my car and it turned out to be the loose connection of one of the wires at the VR sensor. Peel back the rubber boot and give the wires a firm tug - they shouldn't move, Cheers Charlie Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 18, 2015 Share Posted March 18, 2015 Pull it off & look, water can track down wires and fill connectors. Stuffing it full of vaseline is a good answer. Quote Link to comment Share on other sites More sharing options...
Laptom Posted March 19, 2015 Author Share Posted March 19, 2015 Checked the connectors (VR - Coils), but all look like new from inside. Also the trigger wheel looks good. I need to check the wire connections 1 by 1 until I find something. Something should be in there. Will update you guys with possible news. Quote Link to comment Share on other sites More sharing options...
stuck Posted March 19, 2015 Share Posted March 19, 2015 No. 1 injector Fridge? Mine did exactly the same. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 20, 2015 Share Posted March 20, 2015 No. 1 injector Fridge? Mine did exactly the same. Don't remember, it was at least 4 out of the 8! Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 20, 2015 Share Posted March 20, 2015 Im glad you posted that pic fridge. I will be packing all the connectors with vaseline now. Quote Link to comment Share on other sites More sharing options...
iomlt Posted June 16, 2015 Share Posted June 16, 2015 Did this get resolved? I'm too having the exact same issue, mines been installed for 4 - 5 years with no real problems. Quote Link to comment Share on other sites More sharing options...
Laptom Posted July 27, 2015 Author Share Posted July 27, 2015 Yes, It is running again. The stutttering was most likely due to a bad injector (broken internal connector). The non-starting issue was solved by 8 new spark plugs..... Aparantly somebody started my range now and then just to hear it running. My start-up is rather rich, so after a time it smoked mine plugs... Well, after cleaning I have some spares now. Quote Link to comment Share on other sites More sharing options...
