mike12 Posted April 12, 2015 Share Posted April 12, 2015 Hi Guys can anyone shed any light on the issue i am having with ms. I go for a logging run and the afr is in the 3 4 5's i then go into mlv and run a ve analysis and then load that onto the ecu but then when i go for another run i still get the same issue. I have checked lamda wiring and exhaust for leaks both are ok. Thanks in advance Mike Quote Link to comment Share on other sites More sharing options...
Bojerne Posted April 14, 2015 Share Posted April 14, 2015 Maybe a silly question - but you did a Save/Write after the VE analysis ? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 14, 2015 Share Posted April 14, 2015 How are you reading the AFR? Do you have a wideband O2 sensor? Is it actually too rich (does it smell rich) or just reading odd? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 14, 2015 Share Posted April 14, 2015 Get tunerstudio MS... Quote Link to comment Share on other sites More sharing options...
mike12 Posted April 15, 2015 Author Share Posted April 15, 2015 Hi just using the narrow band that was supplied by Nige. Its doesn't smell too bad for a v8 had the plugs out and they are all a light brown colour. Fitted new ones with the correct gap but have since not been back out to check. did save the new ve and load it onto the ecu. Quote Link to comment Share on other sites More sharing options...
Quagmire Posted April 22, 2015 Share Posted April 22, 2015 Narrowband won't tell you a value other than lean/rich. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 22, 2015 Share Posted April 22, 2015 .... but is perfectly sufficient for tuning MS on a RV8. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 23, 2015 Share Posted April 23, 2015 What they said, narrowband cannot measure AFR, the AFR gauge is a lie, ignore it or swap it for some other gauge. A narrowband can ONLY tell you 3 things: Lean (<0.5v) AFR is EXACTLY 14.7:1 (0.5v) Rich (>0.5v) That's it. Most of the time you probably want to be on the rich side, especially idling & under load, cruise is the time to aim for 14.7:1 using the inbuilt O2 correction. That's a generalisation but it's a fairly safe one. Quote Link to comment Share on other sites More sharing options...
muttleyd Posted May 11, 2015 Share Posted May 11, 2015 So if the AFR gauge in megatune with a narrowband is a bit of a waste is it possible to define a gauge that just gives you voltage? Would that make it easier to get an idea of where you are, or is there just too much noise on the signal. Interested as I am going to not the 3.9 with luck next week and as its been off the road for so long the tuning will have to take place on the way to the not station as its not had a not since fitting megasquirt Quote Link to comment Share on other sites More sharing options...
