kevindawes Posted May 1, 2015 Share Posted May 1, 2015 When starting the engine, just after if fires the revs race to over 2k. After about 3 seconds the revs then drop to my preset idles values. Is there a setting I can play with to lower the initial start up revs? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 1, 2015 Share Posted May 1, 2015 Assuming you use an idle control valve, there is a setting for the initial opening of this in the 'More settings' -> 'Idle control'. the setting you want is 'Cranking(dc)', have a play with this Quote Link to comment Share on other sites More sharing options...
kevindawes Posted May 1, 2015 Author Share Posted May 1, 2015 Thank you sir. Quote Link to comment Share on other sites More sharing options...
kevindawes Posted May 4, 2015 Author Share Posted May 4, 2015 I adjusted the setting down and it now starts without racing to 2k revs so happy with that. But now when its warming up and under load it misfires - as if you need to pull the choke out a bit. I re-ran the WAU in TS and its improved a bit. Once it's warmed up to 65 degrees it runs fine. Quote Link to comment Share on other sites More sharing options...
