kevindawes Posted July 26, 2015 Share Posted July 26, 2015 Looks like this caused my ECU to play up. Now trying a loan ecu from Nige, new EDIS, plugs and coil packs and still I get a nasty misfire. Guessing leads and injectors next to try? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 26, 2015 Share Posted July 26, 2015 Cold water or impact. Quote Link to comment Share on other sites More sharing options...
Boydie Posted July 27, 2015 Share Posted July 27, 2015 Moisture is the common cause of the insulator cracking, it gets in between the conductor and insulator and very quickly turns into steam and bingo with the generated steam pressure and corrosion of the conductor that will occur you have a cracked insulator. The easy solution in future is to smear the tops of your spark plugs with high temperature silicon grease before you press the caps on them. Quote Link to comment Share on other sites More sharing options...
kevindawes Posted July 27, 2015 Author Share Posted July 27, 2015 Thanks for the advice. Quote Link to comment Share on other sites More sharing options...
