Theviper1987 Posted August 16, 2015 Share Posted August 16, 2015 Hi I'm 99% sure the edis8 has gone wrong somehow. I'm only getting 1 bright spark then after that they are half as bright out of the left hand side coil packs. I have tried swaping the 'a' & 'b' signal wires(at the edis end) round and then the spark moves across to the other side. I've double checked every wire and every connection. Uv got the vr sensor correct(one way round I get nothing no rpm or spark) the way it is now I get rpm and spark. Is there anything I could have over looked?? The battery is in charge and I'm getting a good 10+v while cranking. Crank rpm is around 140/150. Any help or ideas welcomed. Thanks Quote Link to comment Share on other sites More sharing options...
