Rear air shocks
Troy0456
  • 1 month later...
Eat your Wheatabix (other cereals are available).
TBH if it's pressurised then it's not standard so you'd best fit a pair.
Also, and this is a biggy, if you fit non-genuine (even OEM non-air shocks) onto a car with EAS, check and double check the extended length. If they are too long then at full rebound you will hear a loud POP as the air bag fails, usually at the bottom as it jumps off the seat.
You can rebuild them I'm told, but not at the side of the road.
