Theviper1987 Posted December 9, 2015 Share Posted December 9, 2015 Right the story goes. Iv had my ms running for 6 months ish now with no fault. Now when it ticks over every 5/6 seconds it missed a beat. The rev counter bounced to 0 then back to 800. 10 seconds later it does it again. It's got new plugs, leads etc but still does it. Any ideas. The next step the hammers coming out lol 2 Quote Link to comment Share on other sites More sharing options...
Quagmire Posted December 9, 2015 Share Posted December 9, 2015 What kind of setup you running? Ms1 with EDIS presumably? What do the logs show? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 9, 2015 Share Posted December 9, 2015 They *sound* like resets to me. Do you run capacitors on the coil pack feeds? How are your earths, condition and how are they wired? Sensors to ECU and ECU to battery? 'Power' grounds, such as EDIS straight to battery? As Quagmire says, get a log up here, and we will know more. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 9, 2015 Share Posted December 9, 2015 Rev counter on dash or rev counter on laptop? No need to get frustrated, half the point of MS is you can plug in & see what's going on if there's a problem after all! RPM drops could be VR sensor, or it could as Bowie says be resets caused by spikes or wiring, but let's see some logs before jumping to owt. Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted December 10, 2015 Author Share Posted December 10, 2015 All sorted thanks all. Hammer is safely put back in the draw. It was a faulty spark plug Quote Link to comment Share on other sites More sharing options...
Cheesy Posted December 10, 2015 Share Posted December 10, 2015 Was it really a bad plug? I wouldnt expect that to make it die completely. Or was one of the HT leads too close to the VR sensor wire causing resets? I have had this happen. As an aside what are people using for the VR sensor wire, I havent been able to find any automotive two core shielded wire for this so ended up using some aluminium foil tape and twisting the ground and signal wires. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 11, 2015 Share Posted December 11, 2015 Shielded wire, £1.99 a metre: http://trigger-wheels.com/store/contents/en-uk/d9.html Probably get it cheaper elsewhere, but that works for me. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted December 11, 2015 Share Posted December 11, 2015 I've used standard audio cable for the VR sensor on every MS installation I've done. It works great. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 11, 2015 Share Posted December 11, 2015 Current install uses the shielded cable supplied by Nige (Megasquirt-V8) but I've used normal automotive wire in the past with no issues. Generally, if your setup is that borderline that it makes a difference, something's wrong. Quote Link to comment Share on other sites More sharing options...
