ferdinand Posted January 1, 2016 Share Posted January 1, 2016 best I have a water sensor WKW 000020, which can be placed on a diesel filter. Unfortunately I have no schedule of the three connections and I can nowhere be found unfortunately. The pins are marked 1,2,3 and assume that a + - and at a signal light should but what order. Is there 12 volts on the signal wire? I hope someone can help me. Sincerely, Fer ClercNetherlands Quote Link to comment Share on other sites More sharing options...
duncmc Posted January 1, 2016 Share Posted January 1, 2016 Hi, What car are you dealing with? If I search for WKW 000020 in Google it comes up with a water sensor for the Discovery 2 TD5. Quote Link to comment Share on other sites More sharing options...
Pawl12 Posted January 18, 2016 Share Posted January 18, 2016 For info : on the Disco 2 td5 that sensor is recognised as very unreliable& land rover even issued a service bulletin to suggest removing it if the vehicle dash water in fuel warning light operated excessively. Many td5 owners remove the sensor & tape the eiring connector out of the way. I'll look up the connector wiring in a while if you really think you want touse it. Quote Link to comment Share on other sites More sharing options...
